Hey guy's, missushas a nissan patrol with a factory fitted rb30 , 5 speed. I know it's not a holden but give a guy a break. lol. car has got 196000ks on the clock. Lately been noticing a ticking noise on start up. Oil gauge in the car ranges from 0 - 6 i think. We're lucky for it to get to 1and1/2. Had a full service at 190000ks. I'm thinking maybe a oil pump on the way out. If need be i can hook up an aftermarket oil pressure gauge to the motor to get an exact reading. If so where do i plug the oil line into for the gauge? If it is the oil pump what's involved in removing and replacing pump with a new one. I really appreciate anyone's help with the matter.
cheers ray...![]()
Go the allmighty 308 if the bloody thing will run!!!![]()
the oil pressure sender unit is near the oil filter (large bolt looking thing with 1 wire attached to the end) remove that and attach your oil gauge,
other possible causes are low oil, thinned oil and worn or clogged lifters.
Nobody wants to play with me
