no done this twice and have used auto computers both time all has been good i also pulled out the auto control module which looke like a computer located un der the steering column where that panel is, or unplug it never had any problems with either conversion
if it doesn't have a lion in the badge it not worth having
auto one is fine... driver side of the engine bay theres a relay with 2 thick purple wires going into it.. cut n join them to bypass nuetral switch n problem solved..
unless you have to loom youll need to make your reversing light loom i had to make myne because i didnt get the wiring
harvy1 good pick up forgot bout the mod to those relays love ya work
i read alottt of write ups on how to convert them properly before i did mine its like imprinted in my head step by step >.<
haha
if you dont have the manual loom just make up a two wire one that with female terminals on on end (i think females just check the plug on the box) and near the brakebooster theres a couple looms up there that were from the auto..
you want the white one theres a thickish pink and a green wire... cut them n wire it in
simple as that![]()
ill go grab one of the top loom now
you can see where i tapped into the wires.. couldve done it neater but it worked so yeah lol
then the other ends go to the gearbox plug switch is just a circuit breaker
came up on myne.. ill try again..
