Results 1 to 9 of 9
Thread: UHHHhhhh OHHHHHHHHHHhhhhhhhhh!!!!
    LX SL sedan
    Dec 2008
    Galwer SA
    Default UHHHhhhh OHHHHHHHHHHhhhhhhhhh!!!!
    Was driving home the other night and highbeam stopped working. Low beam is still working fine but high has just stopped working. I know its not globes because neither side will work on high beam. Where should i be looking?
    Adam_88's Avatar
    Adam_88 is offline soon to be boosted
    red VY Ute
    Nov 2008
    canberra
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    check the fuse box in the engine bay
    general the left side will melt and cause probs
    i beleive the headlight fuse is near that end, proberly melted and not contacting properly
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Adam_88's Avatar
    red VY Ute
    Nov 2008
    canberra
    LX SL sedan
    Dec 2008
    Galwer SA
    Its in a VL wagon. When its on High beam the lights are very dull but there is still something there. Would that happen if it was the fuse?
    Oct 2005
    could happen if the fuse is only partial making contact i suppose
    deff pop the lid and look at it, you should see its all melted.
    grab some pliers and pull the fuse out and replace it if you can
    have you cahnged the globes for any new ones? which are more brighter, longer whiter etc??
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    LX SL sedan
    Dec 2008
    Galwer SA
    Oct 2005
    do you drive with you full beam on alot? at night
    this can cause to much draw on the circit and cause over heating on the rail,
    your best bet is to check the fuse box/rail first, if its not there try the indercator stalk/light switch, ive had the light switch break its connection on one of my vls before
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    hahah ive had a worse time with lights. Doing silly buisness in my old VN on a dirt road about 10km away from my house and it was pitch black. I had my hi beams on BAM they went off, we were like 'meh'. So i use my lows for a total of 2 seconds and BAM they are gone too....
    I had nothing in the middle of this dirt road at 12pm. Sooooo me and my friend (who was in the car with me) just flicked on the hazard lights and used them to light the road . We made police car noises allll the way home
    BUT to help with the thread, a fuse actually melted into the fuse box so i had to drop another one in. Pretty annoying, the hi's kept on dropping out but the Lo's worked fine
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
