Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: cold air intake
    silver88vl's Avatar
    silver88vl is offline No milk and juice here
    1990 VN Berlina 5L
    Jan 2005
    Deception bay. Nth brissy
    Default cold air intake
    hey i know a fair bit about cars but i was wondering wot i would need & how to do a cold air intake on my vl commy
    cheers, garth
    jetspin_vn's Avatar
    jetspin_vn is offline JetSpin Racing Team
    VN GTS
    Nov 2003
    Mission Bay, Auckland, New Zealand
    This has been covered a few times, you can fashion your own as I and many others have done. I'm not aware of any commercial solutions for 6 cyl VL's in the cold air department but hey what do I know, I hate paying for anything
    JetSpin Racing Team Mantre:
    "F**k safety, I'm in a hurry"
    VL RB30 Berlina
    Nov 2003
    what i did is cut a hole in the panel with a holesaw get a rubber 90 degree bend a nd a small length of piping and put the pipe through the hole with the rubber elbow underneath and hold it up woth a hose clamp.....got some subber strip the clean up the hole and pipe......it's still a work in progress, but it does the job so far......
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    someone posted a pic on here of what not to do, ducted a feed straight to the lower part of the front bumper - great induction but if road dirt doesnt plug up the air filter first the slightest bit of water will screw your engine.
    just be careful where the pick up is.
    silver88vl's Avatar
    1990 VN Berlina 5L
    Jan 2005
    thanxs yeh im gettin a walky front bar & might put it comin out of one of the side holes.
    jetspin_vn's Avatar
    VN GTS
    Nov 2003
    Quote Originally Posted by vlv8vic
    I think your talking about my system, and while that was the jist of it, there was quite a bit more to it than that in order to avoid debris and water. It's important to design these things right, otherwise as you say *boom!*
    VS executive
    Jan 2005
    so with a walky front for example. and the air intake on the left. thats the cars left. what would you do to make it not go "boom"
    Half a carton and still going!!! Now thats Economy
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    nah it wasnt yours jetspin i cant remember the guys name i dont think he posted after a couple of us commented on the setup. had a big hole hacked into the bumper, just to the side of the grille then a pipe straight from the hole with a few kilos of silastic holding it in the original airbox. looked nasty - and i dare say had a fair bit of 'boom' factor....
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    thanks bex. oh my 100th post. hooray to me. still only a fraction of some of you guys though!!
    dumpd6 Guest
    i dont see that it will be a problem... it use to be just pointing to the ground before i did this, hasnt been on a wet weather drive yet tho
    dumpd6 Guest
    you's two are the only people that have said any thing bad about it... if it looks like it will be trouble ill just cut the pipe back thro a pod on
    pluss you see vr/s with cai out the front of the holes in the front bars an they hav no trouble if any thing ive heard they pick up rocks an you have to clean out your air box every so ofter.... it aint like id be driving thru any rivers
    dumpd6 Guest
    Quote Originally Posted by VLACS
    i know of a vl with a my set up on a walky bar with out a filter and that is still driving around fine
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    apart from the mechanicals of it .... aestheitcally why not duct it straight behind the grill which is already there?
  15. #15
    dumpd6 Guest
    because its too big and hard to bend and fit behind the grille, its only povo ag pipe from mitre 10 and it dont bend verry good and instead of it handing on the ground i thought id be different and put it thru the bumper
  16. #16
    VS executive
    Jan 2005
    you should do what more efficient. im gonna go to the grill from beneath the air box. is a k and n panel filter all the same size. do i have to go in and measure them to find one what fits in my air box
  17. #17
    VL Commodore SL
    Dec 2003
    Country NSW
    Mine goes from airbox to bumper grille via 75 mm pvc pipe, so far no probs rain or otherwise. If its anything like the stock filters the panel size/model should be on the box.
  18. #18
    vlv8vic's Avatar
    M5
    Mar 2005
    Australia
    they may work and you may never have any problems. im just working off the theory of a couple of engine casualties round here (vic) caused by water in some even less agressive intakes.
    (got a mate who stuck a pod filter between the bumper and the wheel on his skyline. sounded great but gave the car a gut full of water cos it was coming straight off the wheel!)
  19. #19
    uuwish Guest
  20. #20
    prizedbnx Guest
    dumpd6, you think you can take a picture of the hole at the front from a bit further back, i want to see the aesthetics of this craftsmanship
  21. #21
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    i have a K&N panel filter with tubing and works well but thinking of changing. i hear that there are regulation changes in regards to pod filters. my cousin got his VP clubsport professionally supercharged and the mechanic fabricated aluminium tubing down through the guard where the airbox used to be and put a pod filter in the wheel arch and it's all meant to be legal. it should work well for me as i have a grp A front bar which directs cold air to the front wheels to cool the brakes.
  22. #22
    prizedbnx Guest
  23. #23
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    It depends on what state you live in, In VIC you must have the pod inside of an airbox (which would defeat the purpose of having it)
    ========My Statesman 20's Mafless and 3.9's========
  24. #24
    prizedbnx Guest
    yeh im from NSW, that rule is dumb, why outlaw a pod filer, i honestly dont understand
  25. #25
    Z()LTAN Guest
    NA ss inducions cai and K&N series 2 panel all the way
    Attached Thumbnails Attached Thumbnails cold air intake-engine-bay.jpg   cold air intake-k-n-filter.jpg   cold air intake-cover.jpg
  1. normal air intake vs pod filter vs cold air intake: fuel economy
    By existentialist in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 09:38 PM
  2. Cold Air Intake
    By RoboticCherry-Coke in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2006, 08:42 PM
  3. Vr Vs Hsv Cold Air Intake
    By bomner12 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2006, 08:53 PM
  4. Cold Air Intake
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2005, 09:25 PM
  5. VP Cold Air Intake
    By habro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2005, 06:26 PM
