Hi All,
just wondering what people look for when they are looking to acquire a project car. The reason I ask is I have a VL sedan, that is now surplus to requirements. I know this is not the For Sale forum, but I don't have enough posts yet, to qualify to post in that forum, which is fair enough.
I wont list the details, as that would then become an ad, and I don't want to do the wrong thing.
So what do potential VL owners look for?
When I can post in the For Sale forum, I will, or if someone wants info and pics just PM me.
She has some minor issues, but is fun to drive, and I would like to see her go to a good home.
rust around the front and rear windows.
Bummer,
only got a little tiny bit at the on passenger side at the bottom joint of the rubber. How much should I have? Only joking, thanks for quick reply.
I did fix up the normal spots under the rear corners of the bonnet, before it got through and started wetting the ECU.
I have seen where people have just put a plastic bag over the ECU, rather than fix the leak!
rust, straight panels clean original interior.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
the few VL's I've look at seem to have leaking power steering hoses, or racks..
a VL is a VL, chances are someone looking for one isn't going to be too worried about the colour, or the features
they'll be more worried about rust, kms and leaks! lol
Rust in boot under parcel shelf under water cascade track around the boot.
Around front and rear windows as well as bottom of doors caused by dry cracked seals at window base...
I'd just look for rust, previous damage and current damage. If it's a project who cares if she has a leaky rack, more then likely it will get replaced or repaired. At the end of the day, if it's a project all u need is a straight body with minimal rust, everything else can be changed or repaired. I know rust and dents can be fixed, but ur gonna be better without them in the first place.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
