Results 1 to 18 of 18
Thread: Windscreen wiper dashboard cluster
    I drive a VL Commodore's Avatar
    I drive a VL Commodore is offline I drive a Skyline, too.
    VL Commodore Poverty Pack
    Jan 2009
    Adelaide, South Australia
    Default Windscreen wiper dashboard cluster
    In regards to this little item, on my 1988 VL Commodore poverty-pack:
    Does anyone have a wiring diagram or can otherwise inform me of the purpose of each one of these wires?
    Reason I am asking is the clip appears to have failed and if I am unable to fix it I will be cutting all the wires and installing a new one.
    Cheers!
    It's as if society expects me to act like a cockmongler when I'm driving the Commodore. People always look at me weird when I go the speed limit, or indicate for more than 2.5 clicks or accelerate moderately off the lights... wtf
    VT spac super6
    Nov 2008
    Riverton sa
    if your just going to cut the wires and put another plug on it why do you need to know what they are for?
    just make sure your connecting the same colours together
    ImAHoon! is offline Banned
    Toyota Camry?
    Oct 2008
    if the clip has "failed" (I assume you mean broken off) why not just tape the plug in? or silicon it (which will still allow you to later remove it)
    Jan 2009
    Quote Originally Posted by harvy1 View Post
    I thought, since I was getting into the dash anyway, I would wire up a simple button array for the wipers and rear demister as both of the satellite arrays are malfunctioning and I am not fond of the standard buttons.
    That is what I need the diagrams for. I have a good understanding of circuits but I cannot work safely if I do not know what wire goes where.
    And by failed I mean that for whatever reason there is absolutely no current being received at the wiper buttons themselves. This may be a fault of the array itself, however I have decided to remove the whole lot as they have caused me significant trouble lately.
    VT spac super6
    Nov 2008
    Riverton sa
    Jan 2009
    i assume you dont have a workshop manual?
    Not on hand, no. But I can get one if it has the relevant data.
    Toyota Camry?
    Oct 2008
    just FYI, I pulled apart a spare switch panel thingo I have here (without breaking anything) and its all pretty straight forward to work out which wires are for which buttons.
    the buttons switch to ground, not sure if that helps you at all.
    vl commodore
    Oct 2008
    newcastle
    1998 vt clubsport replica
    Dec 2008
    Perth, NOR
    do the switches still work if so with a test light or multimetre ull be able to determine which wire does wat
    obviously there will be pwr acc/ and a ground/ and illumiation? there the easy ones then go to the others and switch wiper on and so on.......
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    does the windscreen leak on the drivers side?
    the black box in front of your bonnet release handle is the wiper module, does it get wet?
    wiper switches do stuff up you could just replace it.
    Nobody wants to play with me
    Jan 2009
    I finally got around to actually checking each circuit with a volt tester properly. The backlight works, but none of the windscreen wiper circuits do (the tester hooked directly to each bare wire + the ground wire), nor the demister circuit. The fuses were in good order.
    I get the feeling the problem is staring me in the face and I'll likely feel like a right pillock afterwards, but is there anything else that could cause this?
    I've also been trawling around U-Pull-It looking for a new cluster but they seem to be in short supply. I guess they are a weak point?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by I drive a VL Commodore View Post
    someone mentioned the black control box under the dash, tryed that?
    i never knew it was there until i found it tonight on my car while running my bonnet cable
    as for u pull it, lonsdale or eliz?
    i saw a berlina/calais cluster last weekend at lonsdale and a few normal clusters
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Jan 2009
    Quote Originally Posted by VL Berlina 5speed View Post
    No, I haven't tried it. I'll have a look tomorrow.
    I went to the 'Lizbuff one. Lonsdale is a bit out of my reach since I have to borrow someone else's car whenever I want to get big parts. I might just grab a few hand tools and jump on the train down there though. These clusters aren't especially large.
    Oct 2005
    its screw up on the right hand side, pritty high up never saw it up there before if need be i can get a pic tommorow
    a dude at my old mans work who live up north took a trip down to the lonsdale one and said there is a much bigger and better selection at lonsdale then north.
    ive been over a few berlina/calais cluster, stripped them for parts
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  15. #15
    Jan 2009
    Yeah a pic would help. Found the ECU and a what appears to be a fusebox of some description under the steering column though.
    As for Lonsdale U-Pull-It... I went there this morning. Drove from Salisbury to Hallett Cove and didn't find a single wiper cluster but I did get one defrost cluster. Ended up getting what I needed from a place in Salisbury by the RAAF base.
    The wiper / defrost buttons didn't work (again) but the backlights for both clusters did, exactly the same as the old ones. Makes me wish I hadn't torn them apart to check the circuits. :/
  16. #16
    Oct 2005
    ECU is on the left side of the car, wrong side buddy
    shouldnt be a fuse box under there and the big comp looking one is the auto trans
    its half coverd by the carpet under lay
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  17. #17
    Jan 2009
    I've managed to get the unit unscrewed and disconnected, but there doesn't seem to be any way to test its functionality. Should I just buy another one and test it?
    It's a real pain in the arse to get too, to. I'm not exactly flexible, nor do I take well to being upside down sprawled across the front seats with a handbrake up my clacker.
    EDIT: I plugged it back in and lo-and-behold the wipers worked.... sort of. I would jiggle the box and then use the circuit tester on the old dash cluster and I would get intermittent functionality. Jiggle it again and it would work for a little bit more before stopping.
    I'll go to the wreckers on the weekend and buy a new box. Hopefully its just the box and not the conduits that are faulty. Either way thanks for the help.
    EDIT2: Does this box operate the rear demister too? Because as I've mentioned it seems to be having the same issues as the wipers.
  18. #18
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Yes it does.
    windscreen wiper, washer and demister module.
    Attached Files Attached Files
  1. Windscreen Wiper - Heads up
    By ephect in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2008, 09:53 PM
  2. Windscreen Wiper baldes - How to get them off ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-07-2006, 10:19 PM
  3. Windscreen wiper motor
    By huwbacca in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-06-2006, 05:17 PM
  4. Windscreen Wiper Probs
    By MidZ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2005, 12:05 AM
  5. Windscreen wiper arms
    By The1985divo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2005, 01:26 PM
Tags for this Thread
