Results 1 to 12 of 12
Thread: Vl runnin not so good
    Vl Commodore
    Oct 2008
    Angry Vl runnin not so good
    Hey all,
    My vl which is all stock standered apart from a pod filter seems to be running a lil rough.
    My car wasn't working for around 3 weeks as i needed to replace starter motor but now have replaced it and seems a bit rough on start up and sometime when taking off from lights seems to almost stall. also sometimes when i'm acclerating up to speed it seems to be jearky just feels like small bunny hops.
    The first drive i took it on it ran fine and it was around about a 2hour drive. but took it out last night and about a hour in it started runnin poorly. any help would be great
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Ok check for air leaks b/w AFM and throttle body large hose clamps make sure no air is getting in also vacuum hoses. AFM's play a major role in VL's running crap(Even try another AFM and c if i makes a diff.
    As well as crank angle sensor's. Another could be Dizzy Cup/ Rotor Arm Give light sand 2 - 3 strokes(Check for pitting etc on internal pins and clean off white residue) Leads and Plugs.(check for cracks and white lines on outter insulation on leads and rubber couplers to plugs(White lines in funny patterns means the leads are sparking to the block and loosing power Replace if necessary.
    C how u go and let us know (Check Image)
    Attached Thumbnails Attached Thumbnails Vl runnin not so good-engine1-arrows.jpg
    Vl Commodore
    Oct 2008
    I inspected all the hoses and there are no leaks. i cleaned the AFM connections and made sure they are making good contact. I checked in dizzy cap and there was no white crap anywhere. As for plugs n leads could maybe need new sparkys but leads r new and mechanic put em on around 6 months ago. How do i check CAS? Also i tried undoin my speak plugs but they tight as ****. though i didn't put to much presure on em when i was tryin to turn em incase they broke n got stuck in there
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    use a longer rachet handle for leverage to get the plugs undone, you could also spray alittle crc on them and leave it to soak for a while. when you replace them you only have to tighten them firmly, not really tight. after a while of the heat they tend to expand and naturally become tighter like what the oil cap does.
    Nobody wants to play with me
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Get those plugs out bud and give them a good wire brush'n check the quality of them as in the electrode should be nice and square edges not rounded or discolored. as for the AFM not so much the plug contacts the AFM itself, they r very tempremental for RB30s Running nicely trust me... im on my 4th one the ba*tar#s Good luck keep us posted Chrissa Check this for plug diagnostics http://www.theultralightplace.com/sparkplugs.htm
    Vl Commodore
    Oct 2008
    Awesome i'll try givin them a go after work tomoro.
    Thanks for the info about the spark plugs
    Vl Commodore
    Oct 2008
    hey just tried gettin sparkys out and still havin some problems wit them. i usin socket wit extention and still not movin. i don't wana apply to much pressure to em incase they snap or something. i no it might not do much but would somethin like wd-40 make them any easyer to undo wit out ****ing somethin up. thenks
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    you can spray some Wd40 down on them and let it soak. Does the socket your using have a rubber grommet inside it to help not shatter the porcelin. u may have to use more force and replace all your plugs anyways. At only $3 a plug why not just put new ones in. try not to drop any porceline into the cylinder, then you will be in trouble.
    Vl Commodore
    Oct 2008
    no the socket i'm using doesn't have any rubber in it at all. n i am goin to replace them if i can get them out
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    if u have a universal joint it makes it heaps easier to get the leverage on them.
    They should not be too tight.
    When u replace put them until tight then go say one grunt more...
    Catch my drift...
    Dont overtighten. its just the heat expanding then shrinking on cooling makes them tighter
    Goodluck
    Vl Commodore
    Oct 2008
    ok i got one of the spark plugs out unfortunally i cracked the porcelin but nothin went inside the cylinder. according to the reference u gave me on the spark plugs there are black deposits on it and would most likely be oil fouled or running a bit rich. i did have to top up oil before my starter motor went on me so that leads me to believe that it havin excessive oil consumption. so next step would be fixing that problem and replacing all my sparkplugs.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    To check Mixture/running issues go along these guidelines. Very Helpfull
    RB30 Engine Troubleshooting/Maintenance Step by step
  1. missing & runnin lean
    By RankONE in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2010, 09:52 PM
  2. VS ute runnin bad
    By roger05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2007, 08:04 PM
  3. Runnin' Rich?
    By Jecs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 06:54 PM
  4. whats ur commodore got runnin on the inside
    By damo15 in forum Car Audio
    Last Post: 10-05-2005, 05:15 PM
  5. Runnin hot!!!
    By Robbo74 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2004, 12:02 AM
