Results 1 to 7 of 7
Thread: Oil Pressure Gauge
    VL Berlina Station Wagon
    Sep 2007
    Default Oil Pressure Gauge
    On starting car up cold oil pressure goes to normal high position but then as she warms up needle drops back to first white mark on gauge,not halfway as it used to,and stays there for the rest of trip,however long it might be.The oil and level of oil is ok.I think the oil relief valve in pump is ok too, otherwise symtoms would be different,wouldnt they?Any ideas would be much appreciated, thanks Martin.
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    could be the sensor on the side of the block not measuring the pressure properly. or Gauge is on it way out remembering it is over 20 years old check electrical plugs etc..
    It is on drivers side of the block down near starter motor under plenum.
    could be a blocked valve on sensor
    goodluck
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    does the pressure gauge respond when you rev the engine?
    Ive actually just replaced my gauge with an aftermarket with PSI as the reading. Currently runs at 40psi when driving. I would look into one of those if u want a more accurate gauge, $25 i believe.
    But about ur situation. My pressure goes as high as 50 psi when cold but when totally warmed up it goes to about 25 ish and down when going about 60kph. But when i accelerate its back to 40psi. I dont even know wat measurement the stock oil gauges are, all i know my stock one went to 5 or something.
    Check the gauge first, and as Detox said the gauges are gettin on 20ish years now and im sure that they were never that accurate to begin with.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Sep 2007
    Ok guys,thanks for replies,might have a look at oil sensor as mentioned and see what happens.cheers Martin.Sorry for late reply.
    vl berlina wagon 6cyl
    Jul 2005
    Suzuki Swift GTI
    Dec 2008
    cessnock
    I had a similar problem and the sensor was dirty. I just cleaned it and worked fine.
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    Quote Originally Posted by southy View Post
    yea they do get really dirty down there actually, at first i couldnt see the one on my engine cause it was solid black
  1. Oil pressure gauge
    By crazybiker in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-12-2008, 12:59 PM
  2. Oil pressure gauge
    By sen8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2007, 01:11 PM
  3. Oil Pressure Gauge.
    By ElDubya in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 07:40 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
  5. Oil Pressure gauge
    By Joshua in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2005, 09:31 PM
