Results 1 to 8 of 8
Thread: air con.
    Suzuki Swift GTI
    Dec 2008
    cessnock
    Default air con.
    Hey.
    When i turn the air con and the fan off it sounds like it is leaking. anybody got any ideas wat it might be?
    any help appreciated. thanks
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Wink
    Quote Originally Posted by southy View Post
    Hey.
    Does it work still though?
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    vl berlina wagon 6cyl
    Jul 2005
    Suzuki Swift GTI
    Dec 2008
    cessnock
    Quote Originally Posted by mag View Post
    It still works fine. And the noise stays there until i turn the car off itself.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    is it like a gas leaking hissing sound?
    if so, sounds like the air lines on the back of the slide control have come adrift! have you been mucking around under the dash recently? maybe installed a head unit.
    it is not gas leaking it is the compressed air that activates the various hatches to redirect the air con /heater flow to the different outlets.
    slide the hot cold controller up and down reach under the dash (can't remember which side) feel the cable activating the hatch push it up and off, then undo the the screw that holds the air con cont' pull the controller forward from the top carefully. it won't come out very far you will see about 8 airlines connected/or not to the back reconnect the disconnected one/s if they all appear connected you will need to trace each one back to the other end to check those connections.
    if your not sure ask someone for help, it is not to hard to work it all out but you may need to get someone who knows to help or do it for you, hope this helps.
    Nobody wants to play with me
    Suzuki Swift GTI
    Dec 2008
    cessnock
    yea its like that sound. ive only recently bought the car and it has had a new head unit put in it.
    And thanks heaps for the help.
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by jatsvl View Post
    the cable runs down to the passanger side, it under the dash on a lever.
    as said pop that off,
    undo the screw(straight upwards) for the control panel and pull it outwards should be your problem on the back
    just swap the air flow to the window or feet etc and you will soon figger out it wont change to one of the functions,
    i did it last week when i put my dash together in my vl,
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Suzuki Swift GTI
    Dec 2008
    cessnock
    yeah i think only like 2 of the functions are working. thanks for the help.
