hey guys new to the forum but done some mods usally old kingswoods.
im building a vl using a complete but damaged VP BT1 fitting whole harness n stuff just wondering if the diff center from an indipendant rear will fit the Vl diff.......also if anyone has bypassed the abs any help would be cool.
please dont tell me its too hard or waste of time ect if you have experiance with these item that would be cool
thanks guys
keep on keeping on
the diff will fit but is 300mm longer i think so this means 15inch tyer is the biggest that will fit with out rolling and lipping the guards. you can use the centre out of the vp diff but finding axils is the hard bit.
and with the abs, just dont use it and source a good 1inch master for the vl.
what is the vl your starting with? 6 or an 8?
The irs centre will go in the VL diff but you will need the 28 spline axels to suit
