Results 1 to 19 of 19
Thread: vl supercharging
    s/charged vl
    Jan 2009
    perth
    Default vl supercharging
    hey,
    if anybody needs help with supercharging a vl rb30 motor then ask me anything you need to no been thru it all with what not to do to what to do n do it right
    defantly worth it made it **** a whoooolllleeee lot beter...i can post of piks of moutning ideas to where the belts go and all the gear you need ect ect and tell you a lot of info about it n how its done
    took me a while to sus it all out perfectly..so i thought if anyone wants to do the same as myself n supercharge there vl ill help them out n get it done alot quicker for them..if your in perth i can come up n show ya if ya get stuck/come to me...dun mind putn time in to help another vl driver out
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    been keen on doing this for a while now.
    which kit did you use?
    only one i've heard of is from the castlemaine rod shop and i've heard bad things about that..
    cheers mate
    Quote Originally Posted by vn_v6 View Post
    be A SIICK ****, and weld ur exhaust to your body, that way when u drive, people wont think your exhasut or motor is stock cus it will vibrate and be loud, and be cool
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    sounds interesting, how about posting some more info eg. dyno sheets, 1/4 mile times and over all performance.
    Nobody wants to play with me
    s/charged vl
    Jan 2009
    perth
    kane88
    ay bud ill make a lil diagram for ya n a short list of things i done to mount it the way i done for ya buddy
    this is an old pic i took when i waz 3/4 of the way thru it man so its all a lil messy under the hood haha and like half of it is all like mockup...just to get it running sweet
    if you need any ofther info on the like belhouseing pulley i made,intercooler info on where to run to piping,ecu info,ect ect ect,ill b more than happy to help
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    What sort of power are you making from this setup and what has it cost?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    wow u had to cut up a xf carby body and vl manifold to make that happen? dang i hope it was a pro job.. do u need a throttle body from an xf to do this?
    Cost? kw?
    At what point when driving the car do u use the supercharger? highway use?
    this shits intresting man makes me wanna buy another vl
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    s/charged vl
    Jan 2009
    perth
    i havnt dynod it yet but defantly feels atleast times 2 faster man easyly...haha nah i just have it on flat out haha you can tell the diference ay have it off right keep the throttle in the same possition then turn it on n bam instant power,takes of pretty sweetly...and they surprisingly pump out some mega ****n air ay(and thats with the stock pulley) you can get updated (smaller) aftermarket sc14 pulleys that boost up you psi by a hell of alot(from pulley bros for 150-200$ and a huge psi diferance(thats ****all money for the psi ya gettn))..haha and i rkn they sound pretty sick and defantly worth it....i brought the charger for 400$ of ebay made the mounts done the in n outake piping n away i went(before i added some extra stuff to make it beter)
    these superchargers are of toyotas eg supras and them meen lil drift hatchback things forgot what there called
    as for the throttle body its just of a injected xf man and had the upper plenum welded with an adaprot to fit it and ported out....63mm is the stock throttle body size on a vl..xf throttle body is 84mm i bielive so its a huge diference and doesnt cost stuff all ay..if anyone is interested in doin it i can show em how to fit the tps corectly(throttle possition sensor)it was an assbleed gettn that right haha so ive been thru the wanker parts of it to get it running right
    im no full on guru but i do no some good info if its needed lol
    s/charged vl
    Jan 2009
    perth
    ay goon
    as for the throttle body man i got the upper plenum all welded with the adaption plate and everything for 130$ from sonic injection and the throttle body cost me 10$ from the wreckers....definant cheap efective mod...specialy if your turbo or charged ay...evan just plain n/a definant give it a go
    Sabbath''s Avatar
    Jul 2006
    Goon, there's a thread over on CT which gives you the step by step process on how to put the XF TB onto the VL.
    Got any pictures of the bay now that it's not all in mockup and tidied up?
    s/charged vl
    Jan 2009
    perth
    yeh i seen all there info on there wen i was doin it alot of it helps but some if it is just useless bable about the same problem n no1 is helpn..i got stuck on heaps n nothing was helpn so figured it out meself..the auto and the manual tps is somewhat diferent aswell but yeh..
    ill have to borrow me old lady's camera man..***t me guru one up wen i was recording some wetlaps n out with a couple mates..magot+wet+expesive cameras=just a disaster hahaha
    ill get some more pix soon tho man newest one would have to b(still a lil old) n cant realy see the engine bay verry well is this one
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    the sc14 isnt of a supra
    4agze, came on some mr2s
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    s/charged vl
    Jan 2009
    perth
    hmmmm haha just goin off what ive heard man...but yeh i see what ya saying about the mr2's i no they def on some of them
    Goon's Avatar
    Feb 2006
    GC. QLD
    Wicked Benji, im so buying another VL to do this!!.. im turbo my first vl first hehe
    s/charged vl
    Jan 2009
    perth
    no worries man thats the go mate...need any addvice on anything just gimmie a msg bro but i think you should be fine wasnt to hard to do meself man n im not a complete guru or nothing but yeh any help dont hesitate to ask
  15. #15
    vlt
    Feb 2009
    why would you bother doing this when aftermarked parts to turbo a rb30 are so cheap?
  16. #16
    vlt
    Feb 2009
    s/charged vl
    Jan 2009
    perth
    haha yeh there of a 4cylinder car but when get some aftermarket parts for the charger of pulleybros its worth it....ive seen them chargers with an outcome of 5-15 psi(depending on the charger pulley size) get a aftermarket pulley(smaller) n the psi boosts up dramaticly
    great for a conversion i say from n/a to charged..and not as many hassles n things ya have to change ay
  18. #18
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
  19. #19
    s/charged vl
    Jan 2009
    perth
    nah man i havnt busted one yet ay same afm ive had on there sence i brought it..played around with the mixture screw tho to get the led lights on the computer to show me its not running rich or lean tho..still seems 2 b kickn on well
  1. supercharging vr v6
    By Zuicider in forum Yella Terra
    Last Post: 28-10-2010, 12:49 PM
  2. Supercharging V6 3.8L VS???
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2009, 06:02 PM
  3. Supercharging my vc..
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-06-2006, 03:20 AM
  4. Supercharging My 8
    By EX_FORD_BOY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2004, 04:47 PM
