Results 1 to 3 of 3
Thread: vl starting problems
    vl 89
    Jan 2009
    Unhappy vl starting problems
    Hi people,
    you have probably all seen this thread a thousand times but I'm a sheila and am at my witts end cos I know stuff all about cars!!!
    My son has a vl 89 that died on him about 6 months ago. We got a new battery, still didn't work! We got a new starter motor....still nothing. Had some mates look at it and they said immobiliser was the problem. After fiddling with it for a while they finally got it to started from the starter motor not the ignition. But...2day we have nothing again. We have managed to get radio, head lights wipers etc but no crank/fire at all?????
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    nothing not even cranking and as u say have changed battery could possibly Loose wires on Started Motor.
    Could be the neutral start swith relay located down near the battery (There is 3 Relays located here)screwed to the body check for working relay/corrosion on spade connectors etc.
    Check fuses in fuse box.
    Pull the codes from the ECU as well.
    To do this pull of the passenger side kick panel. Turn screw fully clockwise.
    Ignition ON check for codes. (Red LED represents Tens and green represents Ones.
    Also Check my thread
    Vl Starting Problem Tried the obvious(Sorry New Thread)
    Error Codes
    Code 11 - Crank Angle Sensor and/or Circuit Fault (CAS)
    Code 12 - Air Mass Sensor and/or Circuit Fault (AFM)
    Code 13 - Engine Coolant Temperature Sensor and/or Circuit Fault
    Code 21 - Ignition Signal Missing
    Code 23 - Throttle Position Sensor and/or Circuit Fault (TPS) Press throttle fully to floor to cancel this code
    Code 24 - Transmission Neutral Switch Fault............Move Transmition to Drive then to Neutral then Park to cancel code
    Code 31 - System Pass (OK)- No A/C
    Code 31 - Air Conditioner Circuit Faulty
    Code 32 - Starter Signal Circuit Faulty
    Code 34 - Detonation Sensor Faulty - Turbo version only!
    Code 44 - System Pass (OK) - With A/C
    Goodluck
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by kimbo1970 View Post
    Hi people,
    Crank angle sensor, i replaced my whole dizzy to get her to fire again.
    NOW I HAVE 2 SPARE DIZZYS/CRANK ANGLE SENSORS TO PLAY WITH.
    ps. redo ur tdc timing!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  1. HELP! starting problems...
    By tiphanie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2010, 08:42 PM
  2. VR V8 starting problems
    By jasonb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2006, 11:54 AM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. Problems starting to appear
    By StealthX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 09:24 PM
  5. Problems with starting my car
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-05-2004, 10:20 AM
