Results 1 to 8 of 8
Thread: VL Issues
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Default VL Issues
    Just need a few possibilities for the problem i've got with my VL NA 6.
    Charged the battery up so i could start it after not driving it for a week.
    Put the battery in, jumped in and turned the key to get it started. Turned over once or twice, then fired. Ran for approx 5 seconds and started to get a little low on revs. Started manipulating the throttle to try keep the revs up, the engine was stuttering somewhat in the middle of the revs.
    After 7 or 8 cycles of pressing the throttle, then releasing it to let the engine run i was in the middle of the next throttle application when there was a loud knock from the engine and she died and wouldnt start.
    PS. Found some milky residue in the radiator when i took the battery out this arvo, and i know what that tends to mean, just wondering if the noise and the sludge could be in anyway related?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Milky residue usually means oil is getting in the cooling system or water is getting in to oiling system(As you already know :P). sounds like u may have a cracked head and oil is seeping in to the water jacket. was it a backfire up through your throttle body or sounded more internally early detonation style. generally can cause your AFM to go.
    Can you remember if your car was running hot a week ago and as it cooled it may have cracked the head due to possibly having air bubbles in your cooling system not being bled properly?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    I know this might not be a problem man, but when u get a chance or if u can, check ur tdc timing, she could be totaly retarted = crazy revs = engine runs like crap..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vl berlina wagon 6cyl
    Jul 2005
    the residue can sometimes be from recent use of a radiator water conditioner or leak stopper
    VZ Thunder SS
    Aug 2008
    going by the white sludge....sounds like a blown head gasket or cracked head.
    Sabbath''s Avatar
    Jul 2006
    Wow, totally forgot i made this topic.
    Thanks for all the input.
    The car did finally start again, drove it for 3 days, then it refused to start. Jumped it and it started. Now it's just sitting on the road and the SS is clocking up km's
    Need to get the effort up to check it out. Might throw a better battery at it as that's probabaly half the cause of my starting woes.
    Jul 2005
    try another battery, with most now you cant check each of the 6 cells with a hydrometer, so a bad cell can cause many problems, also when charged the battery can give a good reading
    Goon's Avatar
    Feb 2006
    GC. QLD
    Either that bro or your alternator anit charging right..
  1. V8 VN Issues
    By timgte in forum General
    Last Post: 01-06-2008, 12:30 PM
  2. vr v6 oil issues?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2006, 07:29 PM
  3. Vl Cas Issues
    By hobnog in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-01-2006, 11:24 AM
  4. Known Gen III Issues
    By Fagio in forum General
    Last Post: 11-01-2006, 02:18 AM
  5. Issues
    By PhatVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2005, 09:19 PM
