Results 1 to 12 of 12
Thread: vl radiators
    vl royal
    Feb 2009
    Default vl radiators
    Hi guys does ne1 know how many litres the cooling system holds???im doing a water change and i want to get the coolant mix rite
    1986 VL Berlina, soon to be VK SL 5.0L
    Jan 2009
    According to my workshop manual for the 6cyl it's 10.5 litres.
    My ride: Valerie - 1986 VL Berlina 3.0L auto
    My ride-to-be: Ruby - 1985 VK SL Wagon 5.0L auto
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Sounds right, I filled it up the other day and it took about 9L, but it wasn't completely drained and I needed a touch more from the hose when bleeding it.
    s/charged vl
    Jan 2009
    perth
    the go when having a supercharged or turbo'd vl the best thing to do is chuck in a vl v8 radiator..my radiator bloke siad ****n outh thats the go...want to sure onit anyone else heard of this?
    for the same price as a reconditiond 6 radiator why not get a reconditiond v8 one...4 core instead of a 2 core might b worth a go to keep me car cooler
    when/if i do it(if i dont get any bad feedback from you guys who have heard the donts on this) ill let yas no how it goes
    Bax
    Nothing
    Jan 2004
    QLD
    It wouldn't hurt, when I turbod mine I was still running the original n/a radiator with no troubles at all, in fact my current car is only running the n/a radiator and hasn't been up past half way yet. Gets fairly hot where I am too.
    But having said that, I'm getting a new one soon, and if it's the same price then I wouldn't be hesitating about getting the better of the two.
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    i did a cooling system flush last weekend.
    I had 10 Lt Aloytech 100 Gold and 10Lt of demineralized water was perfect for radiator, overflow reservoir and Bleed.
    Make sure u take out the engine block bolt under the exhaust manifold toward the firewall bottom one to drain block as well :P
    vl berlina wagon 6cyl
    Jul 2005
    must admit I never bother to drain the block, just turn heater on and run hose water thru until its clear
    never forget to remove both bleeder bolts and force water in thru radiator filler until it spurts out both bleeder holes to avoid the steam trap/ cracked head problem
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    Quote Originally Posted by benji-charged-vl View Post
    the v8 radiator has a diffrent entrance for the coolant pipe
    top one is on the LH side unlike the rb30 set up where both top and bottom are on the RH side
    i reckonmend auto radiator as its a 3 core radiator
    where manuals are 2 core
    hence why i have a new auto 3 core radiator in my vl
    just plug off the trans cooler nipples if your cars manual
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by VL Berlina 5speed View Post
    nice, glad i dont have to change mine then
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Jul 2005
    due to the nissan engine being squeezed into the VL, the outlet and intake radiator hoses are on the same side, a baffle in the radiator sends the water across for even cooling, this baffle can come loose, causing all the water to stay on the hose side, causing drastic overheating and cracked head, not a bad idea to feel if radiator is evenly heated after a long run, if loose baffle isnt fixed, same problem returns
    s/charged vl
    Jan 2009
    perth
    VL Berlina 5speed :
    cheers for that info man that helps me a bit there
    harry3 :
    not a bad idea to check that i have never thought of that...coz it seems my car is gettn alot hotter ever sence i got a radiator dude to fix a leak in me car ay
    cheers mate that helped alot hey
    s/charged vl
    Jan 2009
    perth
    got a new radiator from a mate for free..haha the benifits of nowing bulk machanix is the g.o lol scored one of a customers car that was gettn wrecked
  1. Pwr Radiators
    By RVN 355 in forum V8 Development and Modification
    Last Post: 11-02-2007, 08:04 PM
  2. ebay radiators?
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2007, 10:04 PM
  3. passive radiators
    By garfa in forum Car Audio
    Last Post: 14-04-2006, 12:31 AM
  4. Radiators?
    By LiLEd in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2006, 04:42 PM
  5. VT/VX V6 radiators
    By smally in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-01-2006, 01:53 PM
