has anyone replaced the VL door lock cylinders, seems to be an astonishingly slow and difficult job on my workshop manual
I just want to fit new cylinders and keys, is there a simple way of doing this
also how to replace cylinder on wagon tailgate?
its not too hard harry
it will only take 30 minutes max each side for a first timer
2 screws in the arm rest,
and a horse shoe clip on the back edge of the window winder
run your hand along the bottom edge of the door trim card and you will feel its like connected to the door, pull out evenly and it will unclip
do this alll the way around the door trim
slide up and the trim will be off
now the lock mech will have a clip on the rod, should push to one side then the rod will pop off
then simple as slide the fork tag which holds it inplace out and the lock will fall out
if you need any more tips or help just ask i do it day in day out for my job![]()
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
