Results 1 to 19 of 19
Thread: Going insane !!! Plz help.
    VL Commodore Executive
    Nov 2008
    Default Going insane !!! Plz help.
    hey guys,
    just recently bought a vl with 100,000 legit kms.
    BUT
    my RB30 non turbo is making a ticking noise on idle and when i rev the ticking gets faster. can someone plz, plz help me solve this problem because the sound is haunting me in my sleep.
    Nov 2008
    yes i know this question has been asked many times, but all the questions i have seen that relate to my topic, the VL's have done 200,000 and above kms. so plz guys im open to any suggestions, or is the RB30 just a noisy ticking engine in general?
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    get a screwdriver and put it to each injector and listen through it .... could be a dirty injector and cylinders not firing
    SIR LS1
    the two ton go kart
    Nov 2008
    how could it be the lifters? this car has been serviced and had oil changes like no tmorrow lolz, and it was serviced by mobil. and its only done 100,000kms so im pretty sure its not the lifters.
    Nov 2008
    so u think i should go to a mechanic and ask him/her to clean my injectors and put thinnner oil in?
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    no just try what i said first mate, and see if all injectors make a ticking noise through the screwdriver champ
    SIR LS1
    the two ton go kart
    Nov 2008
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    if it increases with revs ill be leaning towards lifters,
    next oil change try some nylon lifter free in the engine and see if i quitens down
    if so then clean them like vl 5speed posted the link too
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Nov 2008
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    maybe an exhaust leak.
    have you checked the manifold studs and nuts? they do come loose, also the rear exhaust manifold studs commonly break
    also check the connection where the manfold joins the exhuast pipe.
    Nobody wants to play with me
    Nov 2008
    jatsvl ill check that today b4 i do anything costly, like changing the lifters.
    Oct 2005
    does sound louder when the camera was on the exhaust side,
    with it running just put your hand around all the edges you can safely reach on the manifold and feel for exhaust gas being blown out
    as jats said look towards the rear first as cylinder 6 exhaust port seems to snapp bolts commonly
    then check over all bolts with a spanner to see if some have snapped (when the cars cool )
    last manifold i did i had to do it 3 times,
    the factory manifold had warped so it just kept blowing the gasket out, so i chucked my spare extractors on and solved the prob
    make sure the manifold is straight before you refit it
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    Nov 2008
    ok later on today ill tighten all the nuts and bolts, and wat do u mean by refit it?
  15. #15
    Oct 2005
    Quote Originally Posted by john_mete View Post
    my bad,
    only if it does have a snapped stud you will have to remove the manifold to get the studs drilled out
    no need to remove it to check
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  16. #16
    Nov 2008
    orite i did the screwdriver to the injector trick, all injecters are making the ticking sound so im 90% sure that its them, i put a bottle of nulon injector cleaner in my petrol 3 days ago aswell as $30 worth of 98 octane mobil petrol. so im on just under half a tank. should the injector cleaner have worked by now?
  17. #17
    Oct 2005
    the injectors are ment to tick, this is them opening and closing releasing the fuel
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  18. #18
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
  19. #19
    Nov 2008
    yeah it does increase with the revs, when i get an oil change and put some engine oil flush and some lifter free stuff in there ill tell ya how i went
    http://www.youtube.com/watch?v=dMOdsoV6lP8 yeah watch that then tell me if that is normal.
  1. girl insane!!!
    By storminalong in forum Electrical Wiring / Questions
    Last Post: 29-04-2007, 02:50 PM
  2. OMG, OMG, This is insane.....
    By NORTI in forum The Pub
    Last Post: 14-11-2006, 07:30 AM
  3. god help me before i go insane
    By statement in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2006, 11:33 AM
  4. Are you insane
    By Hero Man in forum Jokes/Humour
    Last Post: 11-11-2004, 04:45 PM
  5. Insane Engines
    By TheLucksta in forum General
    Last Post: 10-04-2004, 05:42 PM
