Results 1 to 7 of 7
Thread: how do i wire up after market tachometer???
    VR 5-spd BT1
    Sep 2008
    Hobart
    Default how do i wire up after market tachometer???
    i was wondering where i hook the coil wire up to on my vl? the green one
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    theres a purple/pink wire near ur coil brother "push me" its probley tucked away in the loom, mine was.. has black connection on the end. thats for green,, red 12v,, black earth,, white light or 12v..
    if u still cant find it ill post a pic..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VR 5-spd BT1
    Sep 2008
    Hobart
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    i took my dash cluster out and tapped into the wire in the loom where the cluster plugs in. same one that sends the signal from the coil to the factory one. :P
    VLPROJECTING is offline HELP MY VL:)
    vl commodore
    Feb 2009
    sydney
    Hey man i know this is an old thred.
    i found a plug near my alternater it has a pink wire on it the other wire i tested is ground can i run the green wire of my tacho to this pink wire its to the plug that has a black cover on the end.
    can u reply with the picture of yours?
    also Any one have any good idea's of were to mount the tacho and were to route the wires?
    i was thinking of putting the wires behind the cd player onto the passenger side wiring loom as its easier to feed the wired through?
    Goon's Avatar
    Feb 2006
    GC. QLD
    I got my wires running under the dash through the hole where the steering is..atm
    mount the tacho where u like, depending on its size n type will decided where u can have it.. yep green to pink bro wit the black connection. make sure its a good connection or youll get a bouncing needle.
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    right there
    purple/black wire i think(cant remember been a while since i had the dash hood off) im using this signal wire
    Attached Thumbnails Attached Thumbnails how do i wire up after market tachometer???-interior.jpg
LinkBacks (?)
  1. 1 wire or 2 wire O2 Sensor
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2009, 10:05 PM
  2. VDO tachometer signal problem
    By sniperknight in forum Electrical Wiring / Questions
    Last Post: 10-09-2008, 07:26 PM
  3. wiring tachometer
    By bangers in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-01-2007, 11:46 PM
  4. VDO tachometer
    By VNPOWER in forum Parts And Other Items For Sale
    Last Post: 07-08-2005, 05:19 PM
  5. After Market Ecu On Efi Vk 202
    By vkberlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-03-2004, 03:43 PM
