Results 1 to 7 of 7
Thread: help plz auto problems
    vn v8
    Feb 2009
    Default help plz auto problems
    hi my mate just bought a vl with which had a nearly ****ed auto in it we went out and as you do with a new car flogged the ass off it which realy strained the tranny so i had one here which has been sitting in my shed for about 8 months we decied to change them over have done this but now wont select gears at all if in reverse the lights come on but it just wont move im just wondering if maby we didnt line the torque converter up properly or if there could be a problem because the tranny has been sitting around ??? PLZ HELP ME
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    how did u put on the torque convertor? did u line it up on the box or did u bolt it onto the flex plate then slide the box on
    vn v8
    Feb 2009
    hi i slid it onto the box then bolted it all up together just wonderin if the 2 holes on the shaft coming out of the gear box need to be lined up and weather this would maby explain my problem
    VT spac super6
    Nov 2008
    Riverton sa
    sounds like no pressure... first off recheck fluid level
    if not id say yeah converter isnt lined up with the oil pump n by bolting it up like that the front of the pump wouldve collapsed.. time for another new trans if thats the case
    vn sr1 calais-vt exec wagon-vl 304 a9q?
    Jan 2009
    just bought a vl 304 auto and the linkagedoes not feel like its hooked up but pulls park?left it running for a while/no gears/and like steam comming out the tranny dipstick tube-any advice? any tranny specialists out there/i need your help.
    Jan 2009
    also got two six-pot autos out of a vn and a vt wouldnt be of any use too me in the 304 vl would they?
    VL SL Turbo
    Feb 2006
    is the right transmission oil in it? (e.g. DEX III or what ever it needs), and make sure the correct amount is in there 2 (e.g. 3ltrs or what ever it says)
    and check there is no oil split or leaking, because oil leaking onto the exhaust causes smoke hope this help mate
    nick
  1. Auto problems!!!!
    By IBLOWN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2011, 07:44 PM
  2. VX SS S2 auto problems
    By shano8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2008, 09:28 PM
  3. Auto problems
    By immortality in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2007, 03:10 PM
  4. Auto in Gen III WH problems
    By bruzza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 08:17 PM
  5. v6 auto problems
    By vr_for_me in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2005, 04:20 PM
