Results 1 to 4 of 4
Thread: VL Wagon fuel Pumps??
    VKsl + VL Wagon
    May 2008
    Exclamation VL Wagon fuel Pumps??
    Mate of mine has asked me for help with his vl wagon. He can only run it on gas at the moment and not petrol. He's been told the fuel pump has gummed up through lack of use by his mechanic(wanka) imo. i've checked as much by just looking & listening (I can hear it) his so called mechanioc says it could be the low pressure one inside or the high pressure external one not working properly. do VL's have 2 pumps?? Sugestions would be helpfull. Thanks Dave
    vl berlina wagon 6cyl
    Jul 2005
    the 6 cyl models usually have 2 electric pumps, one inside the tank and one under the car near the tank
    both eventually wear out, they can be heard whining, the one in the tank can be heard from near the tank
    the pump in tank is messy but fairly straight forward to repalce
    both pumps are available in several brands, if the outside one shows signs of corrosion its probably old
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    low pressure in the tank, and high pressure in front of the tank, changing the fuel filter ( in front of the high pressure fuel pump under the car) would be a good start if you can hear the pumps working, also make sure the fuel is not stale.
    Nobody wants to play with me
    VKsl + VL Wagon
    May 2008
    Cool
    Cheers guys your right, he's got a manual now showing everything. Looks like fun playing with that.
  1. VZ fuel pumps
    By jbanks in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-01-2009, 06:16 PM
  2. swap VN Wagon and VP sedan fuel pumps?
    By Disperse_daredevil in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-11-2007, 04:37 PM
  3. how much are 5.0L fuel pumps(for VS)
    By shanhsv in forum V8 Development and Modification
    Last Post: 26-10-2006, 12:20 AM
  4. Vr V8 and v6 fuel pumps
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2006, 12:09 PM
  5. vr fuel pumps
    By vr_chaser in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2004, 11:51 PM
