Results 1 to 10 of 10
Thread: Droping the fuel tank
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Droping the fuel tank
    Hey all any tips on what i should do before droping my fuel tank, which has about 10 dollars fuel in it.. then what should i do when ive connected it back to start her again?
    any help with this would be sweet as i need to finsh the boot
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    remove the fuel pump relay
    turn the car on and start till it stalls
    try starting again and make sure it wont run
    this will depressurise the fuel system and will save getting petrol all over your face and what not
    lube up the rubber around the fuel filler cap
    that is a real bitch to get through
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by VL Berlina 5speed View Post
    Cheers man, i guess when starting it up after ive reconnected it & turned the ignition on, the fuel pump should have already pumped the fuel back in to the engine? no need to push the pedal?
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    Quote Originally Posted by Goon View Post
    don't forget, disconnect the negative battery terminal, and take the plate off behind the back wheel to access the filler pipe and vapour hoses. when you have finished and put it all back together turn the key once until you here the pump prime and stop, then turn the key back to off again, then back on until the pump has primed again then start it.
    you should never have to push the pedal when starting a vl rb30, if you do there must be something wrong.
    also you should check the fuel vapour lines attached to the filler pipe and replace the broken ones.
    Nobody wants to play with me
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by jatsvl View Post
    Wicked, thanks mate
    86 VLCT/ 03 II VY SS Ute
    Aug 2007
    you should never have to use the pedal to start any fuel injected car.. and should never use the pedal if the car is on gas either. i droped the tank in my calais its not to hard of a job but can be a little frustrating when trying to put it back in. also be careful i found a nice family of red backs living under there
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by seans VL Calais View Post
    Thanks i get to it tommorow finally! had other car work to do today
    vl berlina wagon 6cyl
    Jul 2005
    theres a complicated system of fuel vapor recovery hoses that all lead forward to the charcoal canister, these hoses are usually rotted, I replaced mine one at a time with rubber fuel hose
    if replacing the in tank fuel pump, get a filter bag that is about the same size as the old one, remember how the old filter bag looks as the pump comes out, if the new bag sticks out too far it will hit side of swirlpot, stopping pump from properly sitting down in swirlpot, causing loud gurgling noises and also car will run out of petrol sooner
    remember, the new in pump tank must fully sit down in the swirlpot
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by harry3 View Post
    Yup Yup. I've had to do this aswell.
    Just make sure you draw up a diagram of where everything goes before you start touching anything because one you start pulling things out you're going to have handfuls of hose and nfi how to put it back together
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers guys, im hoping to get to it tommorow, or i should say today atm lol.. Ive moved my project to the back shed to keep the parts away from the 5speed lol . Having the garden hose close by is something i want incase i get covered in fuel...
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Air Conditioning water not droping from bottom of car VZ
    By kendallsr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-12-2008, 12:48 PM
  3. Very bad fuel odors and presure in fuel tank
    By Helicopter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 01:29 PM
  4. VN Speedo 'droping out'
    By blakio in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2008, 06:51 PM
  5. Fuel economy per tank of fuel
    By HoZy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 05-05-2007, 06:58 PM
