Hi GUys,
Went to remove my boss kit today and discovered why my horn is not working...there is no wiring there
anybody know if this is a HUGE problem?? and does your auto elec or mechanic usually fix this problem??
Thanks again in advance..
p.s. LS1 conversion into a my VL is imminent![]()
the horn should be under the front bumper bar, by the way, a horn button on the dash would be lots easier
and a defect
Pull the boss kit off, and look behind it (in the recess behind the wheel) It's a black wire with gold trace if I remember right. Mine was cut, and shoved behind the boss kit. If its still there, its just a matter of extending the wire. If it's not there, your going to have to run a new wire.
This is how my VN is set up. But i took it to an auto sparky to have it done. Cost me $140, but it fixed it.
(also if the wire is there, and you extend it. Then all of a sudden, the horn only works with the car off, you will need a new ground.)
Hehe I took off my steering wheel about a year and a half ago to figure out why my horn didnt work. Had no wire... still haven't got around to fixing it lol.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
on my boss kit there is a spade connector and another on the back of the horn button one wire with the female connectors joins to both and I have a horn. lol.![]()
Nobody wants to play with me
