whats your pocket depth?
set of wilwood 6 spot calipers front and 4 spot rears - prob looking up to the $10k mark
gearbox wouldnt matter so much, more would be wanting to know which one for strength
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
I think most do the vt brake upgrade for about $1000.
turbo vl has the mx7 gearbox, n/a has the mf5 some would recommend skyline gearboxes.
Nobody wants to play with me
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
vt brake up grade is the go.
well if i had deep pockets id buy the r33 gbox over a vl turbo gear box.you could also try a r32 gbox i have used one of these and they are cheap as to
ive got a r32 5spd in my vl
got it rebuilt and it started making a little noise just before i projected it. this was only with a NA,
although i have a feeling it might off been the thrust bearing only
personally i wouldnt use it on the turbo application if you have a tendcy to drive with a bit of curry
use the mx7 at least if not the r33turbo
a good start on brakes is
disc rear
vt fronts
1"master
turbo/v8 booster
then you can look into it further if your needing more stopping power
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
the r32 turbo box is the same as the mf5 but the r32 box has double synchros in 1st and 2nd.
yeah the price diffrence between vlt box r33 box and r32 is heeps i picked up a good r32 box for 550 with warranty never gave me any trouble abd was very smooth.but id personaly go the 33 box
