whats the idle speed for a auto? and a manual? what should they idle at when warmed up ??
ive searched for this answer n cant find it.... ive found 600rpm somewhere but dosnt say which one its for..
will increasing the timing in advance, increase the idle speed?? it sounds like it does...![]()
not sure on factory idle speed but to turn it up use the screw on the side of the ecu its for idle speed and diagnostics when it is fully turned clockwise.
should be stuck on the passange side strut tower
gives you a step by step guide on setting it
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
700+/- 50 rpm funnily enough both auto and manual have the same idle speed
Nobody wants to play with me
Mines on 1000-1200 lol.
1988 VL Berlina turbo 5 speed
http://forums.justcommodores.com.au/...ml#post1446411
1987 VL SL turbo 5 speed ~STOLEN~
http://forums.justcommodores.com.au/...ed-manual.html
700 approx thats what i set mine 2. ive noticed i could not adjust my idle speed on the ECU Screw i adjusted mine on the screw on the throttle body then made sure the lock nut was tightened.
Same for manual its only a trans thing has nothing to do with the engine, :P
oops.... ahh well i may adjust it back and adjust the one on the plenum. i dont think it would matter though. i hope.
Cheers jatsvl
