Results 1 to 9 of 9
Thread: removing front and rear seats.help.
    VL Commodore Executive
    Nov 2008
    Default removing front and rear seats.help.
    hey guys,
    i couldnt find help on this anywhere??????
    orite i just want to take the front seats out and the rear seats out coz i wanna clean them properly.
    just need instuctions on what to do so i dont damage anything.
    and are they harder to put back in than to take out??
    thanks guys.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    front seats each have four allen key bolts going into the floor, undo them and the seats come out, it helps to adjust the seats all the way forward, undo the back two bolts then adjust the seat all the way back and undo the front two bolts then remove.
    backseats, lower seat first you need to push the front of the lower seat in the centre of the foot wells until the seat pops (sometimes you need to push real hard, I use my knees against the front of the lower seat) then the backrest, on each side where the seat belts bolt to the car there is a metal tab that bends over the seat frame you need to bend that up then pull the bottom of the seat forward then up until it slides off the hooks manouvre it out and your done.
    Nobody wants to play with me
    VL Berlina turbo, VL SL turbo ~STOLEN~
    Aug 2007
    Newcasstle
    Thats a strage way of removing the bottom rear seat. I just put both hands behind the seat in the centre and pull towards and lift up and it pops out.
    Nov 2008
    rofl thanks guys just ended up yanking them out with my dad gently if that makes sense??
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by VL_5SPEED View Post
    It's the way the manual describes to remove the seat.
    I had a problem with the front seats in mine, make sure you ensure that the threads are clean, otherwise they can bind up coming up through the body, causing no end of problems.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    this method damages the seat frame and mounting brackets and causes the gap between the lower seat and backrest to widen and the lower seat doesn't sit flat and flush also seat belt buckles fall down all the time.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    thats the way i do it no probs
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    Quote Originally Posted by gungazza View Post
    aren't vt's different? two lugs straight down. grab the front pull up?
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by jatsvl View Post
    ive got a vl and a vt the vlsgot a blown head gasket at the moment but your right about the vt seats
  1. Removing front seats,
    By vr_owner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2009, 02:28 PM
  2. removing front seats
    By dijm8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-05-2008, 02:21 PM
  3. removing vk front seats
    By dijm8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2007, 11:03 AM
  4. removing vk front seats
    By Vk-5ltr Berlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-01-2007, 06:52 PM
  5. removing front seats
    By run in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 02:04 AM
