Results 1 to 19 of 19
Thread: Loud screaching when turning left ?
    VS l67 statesman
    Dec 2008
    Default Loud screaching when turning left ?
    I have a vl that has a lound screaching sound when turning left,not sure but I think its coming for back left brakes or maynot anyone got any suggestions ?
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    checked your powersteering oil lately?
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    VS l67 statesman
    Dec 2008
    I checked it the level seems fine but the colour is not so good its black, I just got the car today
    social's Avatar
    Nov 2008
    South Aus
    check your front rubber bushes, your power steering rack under the car for starters
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    maybe check rear left wheel bearing. and diff oil.
    Nobody wants to play with me
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    stop doing hand brakies LOL. check ya rubber do hickie under ya var
    vl berlina wagon 6cyl
    Jul 2005
    drain power steering fluid and replace, its self bleeding
    while under car their should be a plastic tube to equalise air pressure in the rack, this is often knocked off by bush bashing and if missing will cause problems eventually
    VS l67 statesman
    Dec 2008
    ok I will check and drain fluid etc, but come to think of I bought it of my friend who is 83 and he always like spinning the wheels so it wouldnt surprise me if he did hand brakeys
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    Quote Originally Posted by vsl67 View Post
    So Grandpa is a Hoon :P
    Mine has a loud screaching sound when i full lock either way but its coming from the belt on the powersteeing pump as it gains a load at full lock :P
    VS l67 statesman
    Dec 2008
    yer it sounds like metal on metal though, but I dont touch the brakes or can find anything rubbing ,but the rear pads do look a little low
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Your not turing to hard are u??
    bushes????
    dont have big tyers with big mags???
    shock or spring could be fked on one side..
    ps. if ur steeering wheel shakes when u drive get a wheel alignment!!
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VS l67 statesman
    Dec 2008
    no its only on light turns ,the wheels are only 15's nothing much bigger than stock & no steering wheel shake
    Goon's Avatar
    Feb 2006
    GC. QLD
    any rubbing marks on the body from the tyers???
    are ur struts cracked???
    VS l67 statesman
    Dec 2008
  15. #15
    Goon's Avatar
    Feb 2006
    GC. QLD
    No none of the above
    Still got the problem mate? id take it to a mechanic...
  16. #16
    VS l67 statesman
    Dec 2008
    Just found the rear axel has movement in it when the brake caliper is removed ,I think the bearing is stuffed
  17. #17
    yz250f
    Nov 2008
    just get a whole new diff. would probably be cheaper.i picked up a diff for my VL for $80 and its a peice of piss to replace.
  18. #18
    jatsvl's Avatar
    vl exec wagon
    Nov 2006
    and a bearing cost around $30
    just do the bearing.
  19. #19
    VS l67 statesman
    Dec 2008
    I found a promblem with the passenger side axel , but when I went to replace it with a new axe out of a VL ,It was too long even though both of them were the short axel ?
    Also since its a disc brake rear I was told the bearing had the drum brake seal in it ,it would cause the movement I have
    But I havent checked that one out yet
  1. clunking noise when turning left
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2010, 10:22 PM
  2. Screaching noise!!!
    By VZMAX in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-02-2009, 09:56 AM
  3. loud noise in left rear wheel
    By johnny b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2009, 07:43 PM
  4. manual gearbox screaching
    By manual crazy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2008, 10:18 PM
  5. Left Wheel Knocking noise when turning at low speed
    By dj_eddie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-01-2008, 09:37 AM
