Results 1 to 4 of 4
Thread: help i'm going nuts trying to find the problem - solved !
    '04 vy s series 2
    Feb 2009
    Default help i'm going nuts trying to find the problem - solved !
    Thanks every one for your input. After 3 AFM's problem was solved after one that wasn't stuffed worked okay ! The trouble is that it was off a car that was running and now i need to seach for a good one. expensive exercise that ! cost about $600 all up plus buying another car ! originally it was the distributor and putting it back 180 degrees out made it backfire and blew the heat wires out ! from there my troubles began. ah well all good experience. thanks again black as, panama, detox_nath83, social,, treezy, woodytoad, goon. couple of you guys were right on the ball with the AFM.
    cheers
    detox_nath83's Avatar
    detox_nath83 is offline Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    '04 vy s series 2
    Feb 2009
    Quote Originally Posted by detox_nath83 View Post
    Mate not a worry thats what we are all here for.
    Glad your back on the road
    Bloody AFM's and CAS
    yeah, it just runs a bit rough on idle and when you put your foot down it hesitates a bit. but i'll fiddle around with that. i'm just glad it's going. i think maybe the timing although it's on 15 degrees. i'll put it to 17* and see how it goes.
    cheers
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Engine Stutter...... Hesitant
    Clean Throttle Body
    Plugs.....Clean or replace
    Leads......Replace
    AAC Valve on Plenum clean make sure inner rod moves freely
    Injector Cleaner
    Clean dizzy/Rotor
    Change Fuel Filter
    C how u go Bud
    no air leaks in intake piping
    wd40/Inox or contact cleaner on contacts for CAS and AFM, Power Transistor, Injectors,Clean Oxy Sensor and spray contacts. :P
  1. Fuel smell in VR ute cab - problem solved!
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-04-2011, 04:31 PM
  2. help i'm going nuts trying to find the problem
    By skookumchuck in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-05-2009, 07:29 AM
  3. Coolant Problem Solved...
    By mrhotdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-07-2008, 05:47 PM
  4. dome nuts....can't find any!!
    By DANNY8 in forum The Pub
    Last Post: 11-01-2008, 08:19 PM
  5. problem solved
    By andle in forum Electrical Wiring / Questions
    Last Post: 04-02-2005, 04:00 PM
