Can someone please help me out with the specs for a factory T3 VL Turbocharger.. please?
*bump*
its highflow!!!....![]()
what specs do you want?
if its highflow then its diffrent to stock
the compressor housings have been machined out to fitt a bigger wheel
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
All I know is that the compressor housing has been machined out and he told me that he put bigger wheels on the compressor + exhaust wheels.
Just wondering what are the common specs for the highflow t3 as I am wanting more power and seeing if enlarging the compressor wheel + housing is feesable?
yes that is highflowed
the way to tell is to look at the lip of the intake on the front compressor housing
normally the lip will get thicker towards the wheel like a funnel towards the point where your transfering the fluid
with a high flow the lip will not be like a funnel but even thickness all the way
as for spec it will vairy on what wheels were used etc
how much more do you want out of the T3? what you currently running (psi/engine comp/setup)
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
The lip on the compressor housing is even all the way to the compressor wheel.
The motor is standard RB30DET, with forged pistons and ported cylinder heads with a N/A cam shaft. it has bigger injectors with a WOLF 3D advanded engine management computer system and front mount and a 3" exhaust.
With fifteen pounds of boost it made 255 rwhp through the standard auto.
It ran a best of 13.7 @ 107 with alot of wheel spin in first gear with standard 3:45 LSD gear ratios.
All im after is low 12's with my setup, what would you recommend as a low dollar performance mod that I use as my daily driver to make a 60 kilometre round trip each day to work as it needs to be economical, thats why i dont want to alter the diff gears?
(i'm having this dictated to me by my man... hope it makes sense!!)
where'd you go mr VL man...![]()
mybad forgot to reply
well if you ahve the set up at its limit tunning abilaty wise then you might want to look into the drive train so it can get the power to the floor
is the diff single wheeling baddly? or still tight
get the trans built to reduce the slop between gears and then look back to power
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
