Results 1 to 5 of 5
Thread: Diff Axle Lenghts for the VL
    VS l67 statesman
    Dec 2008
    Default Diff Axle Lenghts for the VL
    I need to know the diff axles lenghts for the short vl axle ,I just popped my short one out because of too much slop ,I think its out of something else such as a vk because it seem a fraction too long causing me a lot of dramas any Ideas?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    is it 28 spline axle. if it is it wouldnt be out of a vk as theyre borgwarners only had 25's i'm 99% sure
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VS l67 statesman
    Dec 2008
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    how much is a fraction? if its a vl turbo/v8 only two axles it could be was is either that or a vn one but from what ive read vn's are like 20mm longer.
    If its only a fraction longer like a couple of mm you may get away with grinding it down some
    VS l67 statesman
    Dec 2008
    20mm longer sounds about how much it is too long it , whats happening the axel is is bottoming out in the center before the bearing is fully seated in the housing so there is a heap of movement
  1. Holden diff / axle codes
    By Phreddy in forum General
    Last Post: 30-12-2008, 04:02 PM
  2. Will an IRS VR Diff centre fit in a VN V8 Live axle housing?
    By Tas_HSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2008, 11:53 AM
  3. diff/axle questions
    By VL Berlina 5speed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2008, 08:31 PM
  4. Diff oil spec VS V8 live axle
    By OldDog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2008, 03:03 PM
  5. Rear diff/axle noise
    By squire_j in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-01-2006, 09:58 PM
