anybody help me out, my mate who i thought was a mate.. had to hold on to the 2 oil lines so he could get some made up, but the bastard anit answering my calls or nothing no more, i suspect casue he lost his job and probley wants money for them, which its ****ed seeing there mine but i have no recipet ...
any ideas??? apart from the wreckers...
what about the big bolts?? one is rust rooted
i suspect im 1 line short after some research with other threads.. it anit the return feed either as i guess that what the long one is for seeing it has the rubber hose which would possible connect to the return feed line.
possible the oil feed as my other ones bolt is rusted like i said making me thiking its the coolant line..
you are two short
both of them are water lines,
one with rubber pipe is the water return and runs around the head to the starter motor area
the other is the water feed, runs to the water feed hole near back of the block
you need the oil feed which is spiraled and the oil drain which is like a little straight poll of the bottom of the turbo
the big bolts are banjo bolts, you can get them from pirtek
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
yeh just go out to enzed or pirtek and the will make u up a braided line wich will save u hasles in the future![]()
hi mate, i sell both the turbo oil drain and engine oil drain inlet on ebay..
here are links:
STAINLESS STEEL OIL DRAIN for T04Z,T04E,T03,T04 Garrett - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 11-May-09 21:35:12 AEST)
VL TURBO RB30 OIL DRAIN INLET FITTING - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 14-May-09 16:07:12 AEST)
