Please help, I don't have the fuse box lid sticker, to tell which fuse is for what in VL Calais.
I've googled everywhere, asked people, and no one knows. Ideally I'd really like to know which fuse operates the electric aerial ?
If not, where I could get hold of a fuse box lid with the diagram attached ?
Thankyou in advance.
Oh my god. Thankyou so much for the quick reply. Very much appreciated..
Yeah electric antenna...
Cheers !!
I've got a good one with sticker still in tact. If your interested PM me.
Hey, thankyou. I just sent you a message
I have a vl calais also and want to know if there are any fuses inside the car or is there only what is in the fuse box under bonnet??? i noticed below the stering colum there is a cover with some fuse diagrams on back but no fuses?????? can some one confirm that there is only the fuses under bonnet ???? thanks
thread dig!
there are no fuses under the dash in a vl only under the bonnet .
holden used the same lower dash section (including the old fuse box) as the vb-vl.
Nobody wants to play with me
Sweet thanks for that ....
I have a problame windows were working fine and central locking now neither one works ... it must be a fuze but i cant worl it out
your in the wrong spot bloke this is VL section....
source your fuses and relays..
nath he has a vl calais mate,
and yeah check your relays. there are no fuses for your windows and central lock
position 21, 22, 23, 24, all relays but you said none of the two work so #22 power doors and windows circuit breaker the odd one out in your fuse box under the bonnet ( windscreen side third one in from the guard.)
