Results 1 to 23 of 23
Thread: vl turbo?
    vn 5.0
    Apr 2008
    Default vl turbo?
    hey guys thinkin about getting this vl turbo its a factory turbo with a supposed 144000 ks on it just wandering if thats good ks for a turbo as ive only ever owned v8s
    cheers
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    depends on its life........
    has it been treated well or thrashed
    is it stock or is it played with
    more so you will need to look into the body and all the other areas, brakes drivetrain diff
    no point having a turbo vl if the rest wont hold up or match whats done to it
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    vn 5.0
    Apr 2008
    yeah never boosted never thrashed but cumon its a vl turbo i dont beleive it for a second its got adjustable boost intercooler n shit
    but reckons turbos got no play in it blows no smoke no noises or knocks from the motor ??
    vn 5.0
    Apr 2008
    reckons diff is tops and gearbox to but of course hes gona say that hey
    gotta go have a look tommorrow
    Oct 2005
    Quote Originally Posted by vn nut View Post
    its thrashed more then likly
    if its never been boosted then it would be standerd 6-7psi which it would hold fine with the over boost valve
    you dont run a adjustable boost controler for no reason
    just look over the car for rust
    under the rear windscreen and around the front window
    the rear boot rubber lift that off and see how that looks
    check oil cap for milkyness which is a sign of cracked head or gasket
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    vn 5.0
    Apr 2008
    or yeah i know all that stuff he reckons the motors still good im just gonna have to go check her out
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    whats the price???? compare that with the car.. then compare that with the rwc if u need to get that..
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vn 5.0
    Apr 2008
    5500.00 already registered nsw (i think im gona stick to the v8s if i wana turbo i think im beta off building it myself a
    vy2 clubsport
    Feb 2008
    adelaide
    well make sure it has an a8 block.and also make sure its got lw5 on the id tag think thats the code for turbo mtr.
    just give it a good look over.try look at it when its cold on start up for smoke etc
    vn 5.0
    Apr 2008
    yeah engine number is 065874a8 and its vin is AVL018010A
    sounds right a ?
    hes had it for 3 years its currently runnin 10 psi never been past that in his care he reckons and he reckons it blows no smoke at all
    like even if it is good and that how long do you reckon itll last
    im past my thrashin days but still like to have the power there when i need it?
    do yous reckon it sounds the goods or?
    vy2 clubsport
    Feb 2008
    adelaide
    sounds ok.the eng is a og turbo block anyways so thats a plus in your favour.
    i would be starting it up on a cold start thoe so you can listen for noises etc and also when the car is cold on start up the oil seals in turbo have not yet expanded so you will see if the turbo seals are fine.
    my old r33 used to piss out oil when it was cold 1st thing in the morning until it warmed up then it stopped blowing smoke.
    up load some pics
    vn 5.0
    Apr 2008
    vn 5.0
    Apr 2008
    and whats the benefit of the original turbo block?
    suppose its got all the goodies to suit the turbo hey
    not just bolting a turbo on to a stock block?
    Goon's Avatar
    Feb 2006
    GC. QLD
    Looks nice mate and yeah itll have all the right engine internals if its original.
  15. #15
    vy2 clubsport
    Feb 2008
    adelaide
    yeah seen that on ebay i think the starting bid is 5500 thoe?if i got it id do the walky lower but still the mix of 2 doesnt look to bad
  16. #16
    Oct 2005
    bearings and the rods are the same as the NA motor just the pistons are flat (not domed) to lower the compression over the NA motor
    has better oil pump
    diff cam, to stop a flat spot over mid range
    intake manifold is diffrent,
    besides that and the holes for the oil and water its the same
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
  17. #17
    vy2 clubsport
    Feb 2008
    adelaide
    Quote Originally Posted by VL Berlina 5speed View Post
    has better oil pump
    true that but for me it comes down to peice of mind
  18. #18
    vn 5.0
    Apr 2008
    well went and seen it it looks a hell of a lot better on the photos
    and drivin it i thinks id pick a 5.0ltr over the turbo six anyday
    over a stock turbo anyway
    i think ill stick with me 5.0s
  19. #19
    vy2 clubsport
    Feb 2008
    adelaide
    keep an eye out mate dont buy the 1st thing.just because one vl you drive aint that good dont judge them all like that.
    although you could close this topic go buy a tuff tidy vn ss in grey lol
  20. #20
    vn 5.0
    Apr 2008
    yeah im in no rush missus just got given a seca with 35,000 ks on it off her nan so cheerin bout that, goin to have a look at another one tomorrow
    its motor supposedly been rebuilt 10,000 ks ago same for the turbo
    so should go pretty good
    i think i need a bit more money to get sumfn a lil special a?
  21. #21
    vy2 clubsport
    Feb 2008
    adelaide
    maybe.all i know is if your buying somehting with rebuilds get receipts lol.
    but if you want reliability id go the efi 5.0
    whats in your ball park for a car?got any other cars in mind apart from a vl turbo.what state you in?
  22. #22
    vn 5.0
    Apr 2008
    nsw v8s or turbos hey got 5500.00 cash
    yeah thats the thing he reckons he doesnt have the receipts cos his brother in law rebuilt it like yeah pull the other one a
    yeah if i get a 304 i definately want a auto with a stally and cam or its not worth havin
  23. #23
    vy2 clubsport
    Feb 2008
    adelaide
    they all sey that about vl turbos lol
    you mite find a 304 with cam stall etc for that price
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. 383ci single turbo or twin turbo??
    By adictd in forum V8 Development and Modification
    Last Post: 04-12-2008, 07:49 PM
  3. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
