Results 1 to 10 of 10
Thread: brakes playing up
    yz250f
    Nov 2008
    Default brakes playing up
    hey all, my brakes haver recently started to lose pressure at the most random times. ever since i changed the diff in the car and bled all the lines this problem has started. the first time, luckily just as i was coming up my driveway the brake pedal went all the way to the floor and the brake warning light came on. so i bled the lines again thought nothing of it(after the first time i did it my mate forgot to put the lid on the booster amd closed the bonnet so i drove with it like that for 2 days) then it was all fine for a week until i get up to go to work in the morning and get to the end of my street to find the same problem so i left it at the mechanics for the day and they told me i need a new master cylinder. so i pick one up on the way home put it all on bleed the brake lines again, after bleeding the lines the brakes felt really stiff and had a nice feel but after 3 days they feel spongy again. is this what should happen or could there be another leak in the lines?
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    check the vacum line between the booster and cylinder
    make sure it isnt split or leaking
    did you bleed the LH side first then the right?
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    yz250f
    Nov 2008
    no i did the front right to left then the rear left to right. is there a certain pattern to do it?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    The nipples on the capliers arnt leaking??
    try another bleed bro, it took me 2 go's to get mine working again..
    when u replace ur booster did u make sure theres no leaks??
    You dont over use ur brakes do u ???
    new brake fluid??
    Overall try what 5speed said.
    ps. drum on the back ?.. dont worry about them..well i didnt
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    yz250f
    Nov 2008
    ill check the bleed nipples. and its a 5 speed so i hardly use the brakes at all. only really when im at a very low speed. i will bleed them again and hope for the best. i just dont want to be driving and suddenly have no brakes. its scary enough at low speed when it happens
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Quote Originally Posted by MX_Leigh View Post
    Bleed from furthest to closest.
    So on a Commodore:
    LHR
    RHR
    LHF
    RHF
    Checking between each that you've got sufficient fluid in the resy.
    yz250f
    Nov 2008
    ok thanks everyone ill give it a go and see how it turns out. should bleeding it how i did make much of a difference and should it feel spongy or is that something else?
    VT spac super6
    Nov 2008
    Riverton sa
    Goes the same with all braking systems.. start at the furthest point from the master cylinder and work your way in..
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    silly question, but are you bleeding them correctly? do you have some one helping?
    the reason I ask is a mate of mine was having trouble with his brakes I asked him how he bled them and he told me by himself (gravity bleed) went around opening each bleeder until the fluid flowed freely closed it then did the next one and so on.
    Nobody wants to play with me
    yz250f
    Nov 2008
    yea i am doing it correctly. pump up the brake, hold it on slowly undo the bleed nipple then tighten without taking foot off the brake, pump it up again and repeat the process until all the air out the system and its flowing fresh brake fluid
  1. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  2. Help car is playing up
    By Holden Chick in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2008, 05:48 PM
  3. a/c playing up, please help
    By rusty_ss_2233 in forum VR - VS
    Last Post: 09-05-2007, 09:51 PM
  4. playing Around with my VT
    By limnuy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2005, 08:19 AM
  5. Currently Playing
    By Troy711 in forum The Pub
    Last Post: 13-07-2005, 09:54 PM
