Results 1 to 7 of 7
Thread: rear bumper removal
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default rear bumper removal
    How many bolts are holding this thing on?? i also got the tow bar, so would the frame that holds that in the boot be holding that on too???
    shes due for a paint soon...
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    From memory, there are screws holding the edges of the bar into the rear guards, on both sides.
    Then, taking the spare tyre out, there should be atleast two nuts on each side and then maybe 5 running along the inside rear?
    Then it should just be a case of making sure the sides are clear, and pulling towards the rear.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by BLK-SAB View Post
    cheers mate, ill have to take the screws out, i thought they where just holding the strip bumper bits but ill give it a go, gotta install my parking sensor to when i get it off.
    jatsvl's Avatar
    jatsvl is offline NEEDS MORE POWER!
    vl exec wagon
    Nov 2006
    your right all the screws on the inside are holding the strips on you should remove them so nothing gets cracked.
    there are two screws on each side (outside) in the wheel arches then there are two large nuts holding the bumper brackets inside the very back of the boot, there is one 10mm bolt on each side in the centre of the quarter panel they hold the side sliding brackets and nothing on the towbar should be holding the bumper on (except it maybe in a position where you can't slide the bumper off over it, depending on the type and height)
    Nobody wants to play with me
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by jatsvl View Post
    Thanks mate
    vl berlina wagon 6cyl
    Jul 2005
    its very difficult to get the rear bumper back on properly, also the plastic is often brittle and weakened by the sun
    I wouldnt take one off if I could avoid it, remember the 2 number plate lamps in bumper
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by harry3 View Post
    Thanks mate, i almost forgot about the lamps.. i cant wait to get to it, freakn raining again atm I'm keen to kick the other vechiles out of the garage soon lol
  1. VZ SV6/SS Bumper Removal
    By Troy711 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-04-2012, 04:05 PM
  2. rear bumper removal??? help
    By mojo.jojo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-12-2008, 07:12 PM
  3. VN Wagon rear bumper removal
    By Claudy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-01-2007, 04:35 PM
  4. bumper removal
    By vnbelina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2006, 04:36 PM
  5. VT Rear bumper bar removal
    By R-ON in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2005, 07:23 PM
