Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: RB30 injector problem
    VL commodore 5sp man/EB falcon 5sp man
    Apr 2009
    New Gisborne,Vic
    Default RB30 injector problem
    gday, my rb30 injectors are getting power but aren't firing and the EFI relay is all good, thers fuel runing through the rail aswell if any one noes whats goen on pleas help. cheers
    also any 1 wanting to buy a vl rear seat in gook nick pleas ask. cheers
    And any ideas on what i should do with my diff.. i was thingking of welding it so whats the best way to do it?cheers
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    check the Relay near battery one which is connected up to a diode in the loom (3 relays located here, its the one closest to the overflow reservoir) i have had and still have problems with this relay for quite some time now. Probably just an earth problem.
    check for corrosion on terminals/spade connectors and under the plug not just the relay.
    this relay controls the injectors
    Apr 2009
    New Gisborne,Vic
    hey cheers, thers only 1 relay ther?
    but i fount a loose wire and re wired it. this wore ran from the relay to the positive terminal on the battery..now she idles on fuel but if ya try rev it it just dies?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Quote Originally Posted by vl_comm View Post
    try this trick...cover ur afm with ur hand for a second while u rev it, might bring it back to normal
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Apr 2009
    New Gisborne,Vic
    i would give that a crak but now it just idles really ruff for 3-4secs then dies? and still dies straight away wen ya open the throtle?
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    exactly what u r stating is caused by CAS or AFM malfunctioning
    pull the codes from the ECU
    Code 11 - Crank Angle Sensor circuit
    Code 12 - Air flow Meter circuit
    Code 13 - Coolant Temp Sensor circuit
    Code 14 - Vehicle Speed Sensor circuit
    Code 21 - Ignition Signal circuit
    Code 23 - Trottle Switch circuit
    Code 24 - Neutral Start Switch circuit
    Code 31 - System Pass (OK) (Non A/C), A/C circuit (A/C models)
    Code 32 - Starter Signal circuit
    Code 34 - Knock Sensor cicuit (Turbo)
    Code 44 - System Pass (OK) (A/C models)
    Apr 2009
    New Gisborne,Vic
    whers the ecu? and "pull them"? are they like fuses or relays i pull out?
    (im new to VLs)
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    ok
    Behind your passenger side kickpanel is the ECU (Engine Control Unit)
    there is a screw on the side Diognosic Mode Turn this fully clockwise carefully and turn your ignition on
    in the peep hole there is 2 LED's Red and Green
    RED = Tens
    Green = Units
    So if red flashes 2 times then green 3 times that means code 23 Representing Throttle Switch
    press the throttle to cancel this code
    Other codes to cancel is 14 Speed sensor(u can leave it) car needs to go over 10kms to cancel code
    24 Neutral Switch.. Move the gear shifter to Drive then to Neutral and then park to cancel code
    Then keep an eye on further fault codes coming up
    Write down the numbers for us to help u with
    codes are seperated with a slight pause
    Goodluck buddy
    Apr 2009
    New Gisborne,Vic
    ahh ok
    my comms manual?
    and how do ya choose which code to see?
    or..it only flashes the codes that are playing up?
    cheers
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    it will keep showing these codes in a loop u dont choose the code the code represents the problem the car has and then u can rectify
    Dont worry about the 24 code then tell me the codes u get
    Apr 2009
    New Gisborne,Vic
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Apr 2009
    New Gisborne,Vic
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Ok man well that would be your Air Flow Meter(AFM)...Very Common on a vl commodore i have had 3 go on me
    have u got a mate with a vl working u can change it over to see it it fixes the problem. Or try one at a wreckers
    Check the AFM Plug wires under the rubber boot for corroded wires Before hand
    The AFM is the black box in the intake piping attached to the Airbox Lid
    c Pic
    Mate i always keep one spare as well as a Crank Angle Sensor(CAS) another common problem
    Dont forget to turn the screw to take it off diognostic mode and ignition off
  15. #15
    Apr 2009
    New Gisborne,Vic
    ahh ok
    in there, there was a wire sensor or sumthing looking loose.. il try get a pic of it tomorow ans chek the wires.
    also its on gas aswell and runs fine on gas is that a problem?
  16. #16
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  17. #17
    Apr 2009
    New Gisborne,Vic
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    try it first though and keep receipt just incase it was damaged in an accident
    yeah and ring around for cheapest one. anywhere from $40 - $150 depending on the stooge who sells it
    Like i said check the plug under the rubber boot for corrosion
    Goodluck
  19. #19
    Apr 2009
    New Gisborne,Vic
    Apr 2009
    New Gisborne,Vic
    today i added a fue more wires to the wire a found the other day now it runs really really ruff when the throttle is open and idles like normal so do u still think its the AFM?
    cheers
  21. #21
    Goon's Avatar
    Feb 2006
    GC. QLD
    cas or afm man, even check ur timing she could be retarted.
  22. #22
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Thats what i said man
    AFM as it is showing this error in your ECU
    unless it was an old problem and was not reset.
    But exactly what it is doing is the AFM responsible
    then we go onto the CAS if its not the AFM
    if the afm is stuffed when you add more air to the cylinders the AFM is resposible to calculate air flow and add fuel so it runs right
  23. #23
    Apr 2009
    New Gisborne,Vic
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
  25. #25
    Apr 2009
    New Gisborne,Vic
    hey i got a new AFM today and it now is running better on fuel but still really ruff in low revs so should i do sumthn with the CAS?
    cheers
LinkBacks (?)
  1. 17-07-2009, 06:25 PM
  1. Nissan RB30 V Holden RB30???
    By neatvl86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-01-2011, 01:08 AM
  2. injector problem
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2008, 07:26 PM
  3. RB30 N/A major problem
    By andrew1 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-03-2007, 02:21 PM
  4. Injector clicking noise a problem?
    By mcvcomputers in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-08-2006, 05:36 PM
  5. Injector problem
    By hank in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 10:02 PM
Tags for this Thread
