Results 1 to 10 of 10
Thread: rebuild parts ofr turbo what do u suggest?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default rebuild parts ofr turbo what do u suggest?
    Any suggestions on what parts i should rebuild to my engine to have my turbo running sweet..??
    i dont wanna run anymore then 16psi... its just for the rb30 motor.
    I have till the end of july, but i dont wanna have to take the motor even though i have a crane, but what a biatch that is to do..
    Goon.
    ps. i want cheap part ideas.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Goon's Avatar
    Feb 2006
    GC. QLD
    It's just a stage 1 turbo btw, i just want a parts list that would be enough to handle the turbo.
    ps. should i rebuild the auto gearbox? im not intrested in a 5 speed.
    vb sle
    Jan 2009
    adelaide
    how much are you spending? piston,rings,get crank machined block bored new rods thats the main things get a balance,cam,heads ported mains and conrod bearings.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by leigh 7005 View Post
    Do u think 1-2g's is enough ? thats 4 the engine
    VL Berlina 5speed's Avatar
    VL Berlina 5speed is offline Apprentice Panel Pusher
    Project VL Show car, VS Exec, VY Ute, YZ250F
    Oct 2005
    easyist way to work it out is sent a power goal and how you want to achive it
    then look into what combos you can use to achive it and what you need to do it then go look into pricing
    if your just after a good reliable bottom end which will be safe just get everything rebuilt and balanced properly
    possibly change the rods as i beleive they are weakness and your set
    just make sure your tune perfect to suit your set up
    My Rides
    Project VEE EL
    Yamaha YZ250F
    My 'other ride'
    The Aussie PackMule
    SA JustCommodore Section
    Goon's Avatar
    Feb 2006
    GC. QLD
    Quote Originally Posted by VL Berlina 5speed View Post
    On the reliable part, does that include the pistions also? forged is all i can find..
    Aug 2004
    16psi... just use a standard n/a motor no reason why it wont last, allong as the tune is good and u keep 98 in it
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Rb30 rods are good for 300kw according to some people im sure a balanced bottom end will help cope with that. Forgies cost around 1300 unless your in the know so with those theres not much chance to build a decent motor for under 2000. For a good rebuild budget $5000
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    vy2 clubsport
    Feb 2008
    adelaide
    cheap part idea usualy means cheap qaulity lol.save your doas and build something with qaulity
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks guys, im gonna run with the turbo for awhile at 6psi just to be safe.. if it go's ill rebuild.. I'm still gonna save until i get close to having enough for a decent motor or possible just buy the parts over time for the longrun...
    THanks for the help!
  1. vn v6 turbo parts ?????
    By sik-holden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2009, 06:14 PM
  2. what do you suggest?
    By Static89 in forum Car Audio
    Last Post: 03-01-2009, 02:26 PM
  3. V6 Suggested Enhancements - VK Compatible? would you suggest it?
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-05-2005, 01:16 PM
  4. rebuild for turbo
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-02-2005, 06:40 PM
