Hey all this exterior piece has got me stuff, thre plastic clips behind it are stuck in good.. any ideas on the tool or method i should try to get it off?
Ive only broken one piece on my ride so far, i got patience!!
But im buying my manual late tommrow arvo, its about time, but any help before that would be great!!
3 screws in the door edge
one on the point right at the bottom rear
then slide it upwards along the pillar and the clips will slide off the trim and stay in the pillar
then use two small flat screw drivers and get under both sides of the clips to push the tags in and it will drop out
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
