Results 1 to 4 of 4
Thread: vl starter motor problem
    VL 6
    Apr 2009
    Exclamation vl starter motor problem
    just put in a recond starter motor working (pre tested) in to my vl. had to jump start car with jump pack everything all well had power then went to crank the car over and the stater motor crankd but then made a sparking sound and car totally died!???? im sure its just a fuse or something but just thought i would ask for fast help due to not much time and never happend to me b4... thanks and if anyone likes im thinkn of selling...
    detox_nath83's Avatar
    detox_nath83 is online now Another VL Driver
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    Queensland(Sunny Coast)
    did u wire it up correctly making sure the possitive lead is only on the positive contact on starter and not earthing out to body. maybe the starter shat itself(Possible)
    check all connetions are tight
    VL 6
    Apr 2009
    thanks for the help *detox*.. turnd out it was the fuse, now i have power n all that, but still now starter motor wont crank.. just makes a knocking sound... everythings hookd up right to ....??????....
    VL Turbo Commo
    Sea Dogs Champion!
    Aug 2005
    possibly before the fuse went it may have done some damage to the starter motor as well. i know thats what fuses are for to prevent damage. unless a higher amp fuse was used by mistake and has caused damage to starter.
    Knocking sound .....?
    Does it sound like the nut is getting thrown onto the fly wheel (like a "click" sound (solenoid working) but its not turning over?
    I know if a car has been sitting a while and the starter is not working/seized, i have gotten a few going just by smacking it with a spanner (Dont Be Shy Belt it)
    Good luck let us know
  1. Alternator or Starter motor or battery Problem HELP!!!
    By commo69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2008, 07:10 PM
  2. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  3. Possible Starter Motor problem
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 11:31 PM
  4. Starter Motor Problem (VP)
    By kennedymr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2005, 07:21 AM
