i would say goon that the N/A Radiator would be fine. Change the Thermostat to a new one.
I would recommend possibly upgrading it to a Vl V8 Radiator for extra cooling. or go further and get a Alloy high performace type
Your choice and others peoples recommendations would be the key :P
Goodluck
It'd be fine, but you can get a three core or whatever they are in non alloy for 400 dollars from most radiator places.
Alloy would be a waste of money unless you get it insanely cheap and if you're going to be needing it.
If it's only another 30 bucks go for it.
dont touch the ebay alloy ones
i was lookng at one at a radiator shop and the welds had split on the end tanks after a week in a silva
just get a vl 6 auto - thats what im running
its 3 core and will be plenty
good alloy one is about $900 - PWR
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
there are two na 6 radiators 2core and 3core make sure, the one you get is the 3core.
Nobody wants to play with me
yes the 3core is as thick as the tanks and is heavier, the 2core has a lip from the edge of the tank to the core, very noticable if you have seen both or if side by side.
