Results 1 to 15 of 15
Thread: different crank bolt pattern flex plate /flywheel
    vn s1
    Feb 2009
    Angry different crank bolt pattern flex plate /flywheel
    does any 1 know if there is a fly wheel that will bolt up 2 an vn series 1 auto crankshaft as manual has 8 bolts on (fly) & auto has 6 bolts on (flex) i have heard that toyota lexan may have a 6 bolt flywheel or did holden have a flywheel that will bolt up to the auto crank shaft , im trying to get away from changing cranks over
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    vn s1 came out with 6-bolt fly wheel. the 8-bolt fly wheel you have is for vn s2 - vr.
    Vp series 2
    Jun 2008
    none that go straight on.
    you can buy and abaptor or replace the engine. engine replacement would cost about the same as a adaptor, then you have to get a 6 bolt flywheel on top of that.
    cheaper to fit a later model motor.
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    he can get a VN S1 manual fly wheel as they are 6-blot. it will bolt straight on. doesnt need an adaptor plate or an engine swap.
    vn ss
    Sep 2007
    central coast
    i have a series 1 6 bolt flywheel floating around somewhere if interested....
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by centy View Post
    Quote Originally Posted by georgeonboost View Post
    centy right on this one. Manual series one cranks are different therefore you need to buy the sdaptor which only suits 6 bolt flywheels.
    2nd option is to find a manual series 1 motor and swap it for yours should pick up one for half the cost of the adapter then you'll still need the 6 bolt flywheel.
    3rd option is to keep your 8 bolt and swap the motor for a series 2 onwards then you wont need and adapter but will need to change the few other things like radiator and some minor wiring mods.
    I'd go with option number 3 myself
    Most of the information can be found in these 2 threads
    V6 Crankshaft Info
    The complete Vn-Vr Manual Conversion Guide.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    marks adapters make a 6 bolt flywheel, it can be done
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by andyman View Post
    is that a 6 bolt to adapt to an auto crank or just a regular new 6 bolt flywheel?
    Black VN MANUAL
    Feb 2007
    Top of Vic
    CRS addaptor is about $336, goes onto your auto crank and then you can fit the manual flywheel.
    ~ VN POWER ~ Click the scales
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by Bz Kn33z View Post
    CRS addaptor is about $336, goes onto your auto crank and then you can fit the manual 6 bolt flywheel.
    i fixed your post for you it can get confusing when you generalise the flywheels
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    on the VN S1, i thought the fly wheel can be bolted straight onto the auto crank? seeing as that is 6-bolt too? maybe im on the wrong page here?
    Vp series 2
    Jun 2008
    yep on the wrong track.
    early vn has different crankshafts for manual and auto.
    Both are 6 bolt but sit in different positions relative to the block.
    so a straight bolt on is a no.
    You can use an adaptor but it costs, you would also need a 6 bolt flywheel and the engine you have is way old buy now. you could pick up a vr engine and fit it for what the adaptor would cost you.
    Then you can just fit the flywheel you have there and have a newer engine.
    I paid $60 for a full vp engine up here at the dump. it goes real hard to.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Yes they are both 6 bolt but the Manual crank are further apart than the auto crack, so it will not bolt up, thats why you need an addaptor from CRS to convert it, or a flywheel made up but they are like $600 also from CRS.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    A motor usually goes hard before it dies
  15. #15
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    ah i see now...all cleared up
    curleytales - ive got a s2 motor for sale if you're in vic. PM me
    George
  1. 8 Bolt flywheel/flex plate torque settings?
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:23 AM
  2. Checking your Flex Plate(Drive Plate)
    By lazza44 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2006, 10:01 PM
  3. Flex Plate???
    By weedo_86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2006, 05:28 PM
  4. Wanted 8 bolt hole Auto V6 VN-VP flex plate
    By kowan in forum Swap / Wanted to Buy / Trade
    Last Post: 16-03-2006, 10:05 PM
  5. 5.0l bellhousing bolt pattern = chev pattern?
    By 351ghia in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2006, 12:15 AM
