Results 1 to 16 of 16
Thread: Leaks and other misc problems
    Vp commodore 3.8ltr v6
    Feb 2009
    Default Leaks and other misc problems
    gday guys, just thought id lable the things ive fixed or that need fixing after ive had my car for around a month
    leaking seals
    door lock broken... so anoying
    have water getting into the boot (thinking its coming from the light)
    so need to fix the seals on the back rear light (thinking about drilling a small hole unter the light to drain the water)
    rear left speaker has stoped working
    horn is on the blink
    oil leak from the steering somwhere (got a new steering rack and pinion and bushes for roady)
    haha guess you cant expect anything else for uner 3 grand,
    once its all done sould be sweet
    these all sound common?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Ooooh yeah. Common alright. I've fixed every one of those things at least once myself
    My statesman had a broken door lock, leaking seals, broken window, oil leak from steering, oil leak from transmission, two broken speakers, broken head unit, etc etc.
    Believe me, that's a short list for you
    The 1972 HQ Kingswood
    Feb 2009
    good to see im not the only one haha
    i have stoped the oil leak fixed the seals, but only found the other in the past few days
    of to the wreckers for me hah
    Morton's Avatar
    May 2006
    Ahh, here we go. I just found the list of parts I replaced on my first VP Executive:
    2x rear disc rotors
    power steering rack
    reco power steering pump
    front swaybar link pin rubbers
    rear swaybar link pin rubbers
    auto trans fluid and filter
    LHS rocker cover gasket
    oil pressure switch
    tailshaft centre bearing
    rear upper control arms, box type
    inhibutor switch
    windscreen washers
    heater fan switch
    brake lights
    trans mount
    rear muffler
    rear trailing arm lower bushes
    entire hub-to-hub diff
    console lights
    and that's only the stuff I kept receipts for
    Feb 2009
    Morton's Avatar
    May 2006
    nah, you'll be fine Once you've got it roadworthy, you can pretty much ignore most of the problems the old girls give you. Just service them regularly, drive them easy, and they'll last you a long time
    ... unless of course you're a picky bastard like me, in which case you'll be pulling the whole thing apart every other week to fix things like blocked heater cores.
    Feb 2009
    god dam! thats so much work haha,
    i wouldnt have the guts to pull it apart and trust myself to put it back right haha
    Vp series 2
    Jun 2008
    hell my first had a few things wrong with it.
    It was taken for a quote for roadworthy and was written of on that quote, $3500.
    windscreen
    tyres
    ball joint boots
    1 tierod end
    sump gasket leak
    trans rear seal
    bearing plates
    bent bonnet hinge bracket
    sagging roof
    front brake pads
    some rear end rubbers
    sway bar links
    shagged steering wheel.
    done all the work my self and done extra and the parts cost the same as quoted withh extra done.
    Feb 2009
    wow, thats a huge quote good work doing it all yourself. i guess i got of lucky,
    hopefully i have fixed the water leak in the boot, the newer lights bolts werent tightened so i did that and am goin to run a bead of silicone around the top, see how it goes
    have fixed the rear speaker, the leak from the engine remains a mystery as it has not been dropping anything since.... who knows haha!
    and the horn is working slightly better, no idea why....
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    Quote Originally Posted by lachie View Post
    leaking seals
    3 grand i bought my current vp for 750 and replaced the water pump and 4 new tyers for roadworthy and it came with full tinted windows and mags no rust or anything 2 weeks later i got a vn s1 for around 100 bucks in the same order either way good luck treat it right and it will treat you right
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    lol Morton, after reading ur list of problems then looking at ur plates all i read was AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAA!!!!
    hahah, my bros VN has probs too:
    Rear door seals fell out,
    scrubs tires like a mofo
    needs new rotors, pads were just done
    power steering leaks like a tap on its way to bunnings
    at the moment the steering is farked, its allover the place and UN-DRIVEABLE (fixing soon)
    tailshaft is on its way out
    trans slips and isnt responsive
    welshplug went, but he never uses rad fluid so its clogged up (FIXED)
    all the gauges stick, revs, speedo, fuel, temp... all of em.
    the torque converter (i swear) really starts makin noise up a certain hill
    air con broken
    fans dont work until the 3rd notch (nothing, nothing, eyebrows are gone)
    blows smoke now and then
    motor uses oil
    its got a toyota badge, HUGE problem
    exhaust actually fell out at the cat converter, sounded like a tank. Fixed it and held it there with speaker wire (still holding!)
    only one low beam light works
    has a second toyota badge
    Runs like pig shit, steering is floaty when it works, brakes suck and the interior is ruined.
    Mind you,
    Its still using oil a year old (looks like tarmac), spark plugs are just as old, air filter is over 2-3 years old, never had rad fluid, trans hasnt been serviced in years, at one point didnt have power steering fluid for ages, interior is always full of rubbish ect ect.
    so yea, they can have their problems.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Feb 2009
    dam you bro treats his car like crap haha
    rob were do u find these cars!!
    sooo jelous
    Jun 2008
    golden beach
    sooo jelous
    my current driver was on ebay i snapped it up fast and the vn was from a friend of a friend without a brain just lucky i suppose i paid 175 for my first vp needed the oil pickup cleaned did so and over a few meets killed it on the strip just keep ya ear to the ground there always cheep and for the most part they have
    very little to do to them having said that i do all my own work i do enjoy playing with my vn vps so all up ive had a few of them now oh and as a rule of thumb if its bog stock don't pay over 1000 for it heres what i got for 750 heres my new on road car
  15. #15
    Feb 2009
  16. #16
    Jun 2008
    golden beach
    keep it in mind for your next one truth is ya don't know unless your told
  1. FS: Misc parts.
    By Cody in forum Parts And Other Items For Sale
    Last Post: 18-03-2008, 03:53 PM
  2. FS [WA] VT & VX Holden & HSV misc parts
    By EXCESSV in forum Parts And Other Items For Sale
    Last Post: 25-02-2007, 07:42 PM
  3. lowering, gas, paintjobs and misc...
    By bognog in forum General
    Last Post: 01-09-2006, 07:27 PM
  4. wtb misc bits
    By mr vq in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2006, 08:03 PM
