Results 1 to 6 of 6
Thread: diff gears/yolk?
    vn calais v8
    May 2009
    vic/geelong
    Default diff gears/yolk?
    hey guys have vn wit lsd was wondering if anyone could tell me if 4 11 diff centre would fit straight in to diff or do i need a different yolk centre thats in is just standard 3,08
    georgeonboost's Avatar
    georgeonboost is offline clutch it!
    slammed VP EXEC
    Jun 2005
    Melb SE Suburbs
    when you buy the diff gears, you should get the crown gear and the pinion. they will be 4.11's (as you want) and both of them need to be changed. you can't leave the 3.08 pinion and the 4.11 crown of vise versa.
    fitting diff should be left with professionals as the correct backlash needs to be set in the diff gears so it doesn't chew the gears and render them useless which could lead you to needing a new diff and gears.
    George
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Also 4.11s are found in pintara's so soures out a pintara and get the 4.11s out of them, or or R31 Skylines have 3.9s
    ~ VN POWER ~ Click the scales
    vn calais v8
    May 2009
    vic/geelong
    ta i have the 2 centres one 411 out of car other 3.08 in car was just gonna swap the 3.08 to 4 11 so cant be done like that? wat need if already have whole centre and any ideas how much
    vn calais, vs clubsport #137
    Jun 2005
    i paid $190 to have my gears swapped over, they swap the crownwheel and pinions over, your standard yolk is fine as the splines are still the same on the pinons.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Not a bad price And yeah, the whole thing should just pop in OP.
    The 1972 HQ Kingswood
  1. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  2. question about diff gears in a irs diff vs 5.0l
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2008, 04:21 PM
  3. WTB: 3.73 Diff Gears Suit VS Diff
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 11-08-2008, 02:51 PM
  4. diff gears 3.45 or 3.7???
    By stateo 304 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2006, 02:03 PM
  5. diff gears
    By scared_ in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-08-2006, 12:16 PM
