Results 1 to 6 of 6
Thread: Revving too high when cold and taking ages to warm up
    VS Commodore Esteem
    May 2009
    Default Revving too high when cold and taking ages to warm up
    I am trying to suss out a problem with a VP commodore.
    OK starting the car from cold, it revs too high when driving and wont shift gear when the car is going about 60-70km like it normally would until it has taken about 15 min to warm up, then it finally shifts into the right gear. But the time it is taking to shift is getting longer and longer. It used to take about 5 min.. now its taking about 15 min. I can take the car to 90km and rev the crap out of it and it will change sooner but I dont want to cause damage over time. Something is wrong.
    Anyone know what the go is? Someone told me auto choke but the car is EFI so it can't be.
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    Sounds like a blocked filter in the transmission to me, with the needing to wait for the trans fluid to thin out (warm up) before it'll shift properly.
    As for long warmups, try a hotter thermostat?
    Check out my VP right 'ere!
    VS Commodore Esteem
    May 2009
    I just called a couple of mechanic's and one said the neoprene seals in the gearbox may be shot so I would be up for a full replacement ~ $1800 - 2000. Otherwise I could get a service and an additive which could loosen them up after it had been driven for 100km or so, but that might just be throwing good money after bad. One guy said it could be the filter.. he has had that happen but it could be klutch gear gunking up everything.
    I asked one about the filter and he said that it probably wouldn't be going well at all if that was the case... that it would just rev in neutral.
    Only paid $1500 for the car of a family friend who is a dealer and don't have 2 grand to spend on a new box.
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    Well there's a magnet in the trans sump that should attract most metal shavings (which will need cleaning off if you service it yourself). Honestly I'd go for the filter first, it's a bit of a gamble, but in this day and age, what's $45 for a service kit and $20 for fluid and do it yourself?
    VS Commodore Esteem
    May 2009
    camstatic's Avatar
    VP S1 V6 Executive
    May 2006
    Regional SA
    No problem, hope we've got ya going in the right direction.
  1. Cruise control - revving too high, staying in 3rd??
    By Raging Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2007, 09:32 PM
  2. V6 runs cold, slow to warm, doesn't hold temperature, bad fuel economy
    By fixedit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2006, 10:11 AM
  3. 1996 VS Taking 10 minutes to warm up
    By COWSPUD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-05-2006, 05:19 PM
  4. Strange noise under accell/revving whilst cold
    By vaertigo in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-12-2005, 10:08 PM
  5. VN stalls after taking a corner when cold
    By nole in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 10:22 AM
