Results 1 to 25 of 25
Thread: vn v6 extractors/exhuast?
    vn calais v8
    May 2009
    vic/geelong
    Question vn v6 extractors/exhuast?
    hey people just wonderin wat reasonable price for vn v6 pacemakers 2 hand and 2 and a 1/2 inch exhuast pretty much new not fitted?????????
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Extractors can be had second hand for between $150 - $300
    2.5" catback:
    redback with two mufflers second hand: $100; brand new: $250
    other random brands with two mufflers: $100; brand new $200
    other random brands with one muffler: $50; brand new $150
    The 1972 HQ Kingswood
    89 VN
    Feb 2009
    I just brought pacies for my VN V6, haven't fitted them yet. is it much of a job like whats required?
    Came off a VR V6 and the O2 sensors different any idea's?
    hagz u may not need a 2.1/2" cat back system you could chop out a muffler
    Morton's Avatar
    May 2006
    The pacies are a bit painful to install, but it's possible. You just have to get the car really high up in the air to slot the bastards in
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Prices? Not sure.
    Doing them though on a VN is quite a pain.
    The steering rack and pinion has to be dropped.
    -=EDIT=-
    Grr. Morton beat me to it >_<
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    89 VN
    Feb 2009
    Ahhh i hope your kidding that's a bitch.
    Not just that but the VR O2 sensor has 3 wires the VN's only have 1 and a different fitting where it sits in the exhaust. will these go on?
    Morton's Avatar
    May 2006
    Stick your oxy sensor in.
    camstatic's Avatar
    camstatic is offline on cruise-control
    VP S1 V6 Executive
    May 2006
    Regional SA
    You need to extend the wires on your current o2 sensor, or weld a thread into the pass side set of extractors at about just after where the 3 primaries merge, stick your o2 sensor in there, and put a bung in the VR sensor thread which is right down near the cat.
    Check out my VP right 'ere!
    VR Commodore V6
    Sep 2008
    Sydney NSW
    1. No. We weren't kidding about it being a pain in the ass.
    2. Stick your O2 sensor in as Morton said.
    3. Extend your wires like camstatic said. It's not that hard to extend a 1-wire O2 sensor
    vn calais v8
    May 2009
    vic/geelong
    cheers for that sellin it wasnt sure wat to ask and yeah they a pain to get off so wouldn be any easier puttin em on
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Everything to do with the drivers side on the VNs are an absolute PAIN...to say the least.
    There is just NO room to do anything on the drivers side of that engine bay. It's ludicrous.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i got my pacemakers pretty new but used for $150 and a mandrel bent exhaust off ebay $180 and sounds pretty tuff, as said above pacemakers are a pain in the ass to install,
    2bolts for steering rack to be taken down, another bolt for the spline which the whole installation of the pacemakers the hardest bit is the steering rack part, drivers side is a 2 peice, passenger is a one peice and easy to put in, there is enough room to do it on if you have car ramps, also on the VR the exhaust sensor is down further as said, and the wire will need extending but i dont reccomend it, because its reading both sides of the exhaust and plays tricks on the computer my engine light comes off and on all the time because of this, i will be removing the bung on the extractor and putting it there insted so that should solve the problem.
    if you have a mate to help its not as hard, but a VN with pacemakers and 2.5 exhaust with 1 muffler sounds good for what it is. insted of just a 2 1/4 with no resi
    ~ VN POWER ~ Click the scales
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Or your own brand of exhaust, dumped at the diff, no mufflers, probably 20 bucks And with them money you save, hit the wreckers and get yourself some diff gears out of a Pintara
    89 VN
    Feb 2009
    Thank you guys 4 the help even though this is not my thread lol.
    This may sound dodgy but could u solder the 3 wires in2 my 1 would this work.
    The fitting on the VR is much smaller to a VN 1 or should i just take it to a small workshop and have them do all the stuffing around how much do u think they would charge?
  15. #15
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i am pretty sure the O2 sensors are the same size where they bolt up, just have more wires use your o2 sensor not the vr one, if it wont bolt up get an exhaust place to fix it up for stuff all.
  16. #16
    89 VN
    Feb 2009
    Yeah they may have to cut it out and put in a bigger thread 4 a VN O2 sensor.
    I never thought it would be this much work when i brought them damm it!!
  17. #17
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Curios to know...why DID you buy VR extractors?
  18. #18
    89 VN
    Feb 2009
    The guy said they would fit mate i didn't know. I had some more conversation with some guys i work with and they said they probably wont fit the Y piece.
  19. #19
    Black VN MANUAL
    Feb 2007
    Top of Vic
    i got vr pacemakers aswell, and they are fine, also has the manual Y pipe and i had an auto and no rattles or anything, its really not that big of a deal the exhaust place will fix it up in no time take it into them if they are not on the car and get them to do it and it will be cheap as piss, VN to VR are the same unless its S2 VN competion pacemakers they are bigger and they dont fit on a S1 VN what is the part number on the pacemakers?
  20. #20
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    when i had my starter done the left extractor had to come off and the steering rack vn's are not packaged very well imho, sorry to veer off the subject slightly. mort prices spot on
    ========My Statesman 20's Mafless and 3.9's========
  21. #21
    89 VN
    Feb 2009
    I dont have a part number soz.
    I will go to an exhaust place and see how it goes.
    Also how do i know what gaskets to get?
  22. #22
    Vp series 2
    Jun 2008
    I put a set of use gm extractors on a vp a while ago and they were not to hard to drop in. Nice and short with a bolt up flange on the bottom. A little twisting and in they went with everything in place, later i found the power steering hoses were closer then i would like so i bent the fittings a little.
  23. #23
    89 VN
    Feb 2009
  24. #24
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Morton's prices are about right. I picked up a set of Paceys for my VN V6 for $150, I think. Can't remember for sure, but it was around that mark. Easy enough to fit if you have half a clue what to do with a spanner.
    WTB: mulberry VN interior parts
  25. #25
    vn calais v8
    May 2009
    vic/geelong
    cheers heaps guys
  1. Irs, LSD. same exhuast?
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-05-2009, 08:43 PM
  2. What Exhuast??
    By SiLeNt-SoN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-01-2008, 11:01 PM
  3. vp exhuast
    By FCCOOL in forum V8 Development and Modification
    Last Post: 24-10-2007, 08:14 PM
  4. VN V6 Exhuast
    By statesman_wagon89 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 03:10 PM
  5. Exhuast
    By midnight.outlaw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2004, 08:09 PM
