Results 1 to 5 of 5
Thread: VN/P cooling fan wiring
    VL Wgn & VL Sdn
    May 2009
    The Shed...W.A.
    Default VN/P cooling fan wiring
    G/day guy's, was just wondering if someone could tell me if the wiring for a V8 cooling fan is the same as a V6 ?
    I am fitting a Gilmore Drive to my son's car an he is fitting a new shroud with electric cooling fans. Does the wiring stay the same, and can we connect to the same harness.
    Regards oldboi
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    id run it to a switch im aware you arnt asking that question but at least it gives you more control
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    check this How to fit thermo fan bypass switch it has all the answers to almost every question you will probaly come up with in regards to this subject
    in short. yes the loom is the same, just remove the external electric fan that is fitted for the aircon (assuming you have aircon) and wire the thermo's into this circuit. you may have to put a bigger fuse in for the bigger twin thermos. then you need to get the tune altered on the memcal to turn the fans on at the apropriate temperature (when it's used for the aircon it doens't turn on untill a much higher temperature)
    Body by Holden, Soul by Brock
    the Legend will live forever
    Vt-Brrrlina is online now vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    or as rob said run ur own temp switch - this is what i have done with my twin thermos, cost me 40 bux for the temp switch and it has a adjustable thing on it - so i can choose what temp to turn it on
    VL Wgn & VL Sdn
    May 2009
    The Shed...W.A.
    Cheers guy's, for the reply's.
    We wired the thermo fans with a switch as per threads i read, seemed the best way.
    Regards oldboi
  1. cooling fan wiring diagram
    By pumba4 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-01-2007, 11:31 AM
  2. Oil Cooling?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-12-2006, 01:31 AM
  3. VS air con not cooling.
    By shmity in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2005, 07:46 AM
  4. Amp Cooling
    By VY2ENJOY in forum Car Audio
    Last Post: 22-10-2005, 12:54 AM
  5. vn s1 cooling
    By fatvgute in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 11:24 PM
