Results 1 to 7 of 7
Thread: 5L help
    VNSS Atlas Grey
    Feb 2006
    Default 5L help
    hey all
    I did a fault check and i got a code 12.. but the car hasn't been running right for a very long time and a get a code 12 ( Check Passed) i don't get it.
    VN V6 0-60mph in 7.52
    Peter Brock
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    VNSS Atlas Grey
    Feb 2006
    the car idles really ruff and the tacho is really playing up and it blow alot of black smoke when i've given it a boot full
    Peter Brock
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    start by resetting the computer, sometimes this can help with rough idle, tacho playing upcould be many things if its jumping all over the place sometimes this means coil, but im pretty sure on these newer cars it comes from the computer which is read from the Crank angle sensor, is the black smoke worse when cold? mine puffs a little black smoke when you boot it.
    I would suggest giving the car a service if you haven't already and try some new plugs also.
    VNSS Atlas Grey
    Feb 2006
    tried new plugs, i got a MSD ignition coil on it now done a service. i was reading somewhere that it could be faulty air flow meter?? where are they located?? front of the intake manifold
    Peter Brock
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    VN 5l doesnt have an airflow meter.check the fuel regulator vacuam hose for fuel clean the IAC valve on the throttlebody and the hole it gies in,and after that start looking at the ignition module and the hall effect sensor in the dizzy.also good to check the coolant temp sensor.the ecu has been know to be at fault a lot with issues with richness due to the coolant temp system in the ecu frying alot too.
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    tacho can short out inside too, causes engine to not run at all eventually. try disconnect it.
