Results 1 to 5 of 5
Thread: flexplate bolts
    vn commodore
    Feb 2009
    Default flexplate bolts
    hi all
    i just replaced the rear main seal in my vn series II
    and i replaced the flexplate but the problem is i am having problems tightening the bolts on the flexplate they go in fine but they will not torque up to 90nm as it says in the manual they will tighten up to an extent than they just turn like its about to snap are these bolts torque to yield bolts
    or am i losing my marbles
    cheers
    cameron
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah mate you should get new bolts when replacing these i think their torque to yeild im not sure but they snap quite easy
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Hold up! Specs are 18-22nm + 73 degrees. Thats for the 8-bold S2 pattern. 6-bolt S1 pattern may be 90nm as they are bigger bolts.
    I also highly recommend using new bolts.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vn commodore
    Feb 2009
    thanks for the replies i will get new bolts (theyre most likely stretched) is there any place that supply these bolts? or do i have to buy them genuine?
    cheers
    cameron
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah mate just take the old one to a bolt joint and get them to sort you out
    Denuine ones are expensive
    If you get them from a bolt joint make sure their matching tensile strength and use loctite on them.
  1. Vr 3.8 fexplate and vt l67 flexplate the same?
    By 6 shooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2009, 08:22 PM
  2. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  3. Flexplate to crankshaft replacement bolts
    By centy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-08-2008, 08:59 AM
  4. Flexplate bolt tension
    Last Post: 24-08-2008, 01:25 AM
  5. flexplate replacement
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-02-2008, 05:29 PM
