Results 1 to 18 of 18
Thread: What Have i Done HELP HELP HELP HELP
    VR, VX, VN Commodore's
    Dec 2008
    Default What Have i Done HELP HELP HELP HELP
    i was driving along a dirt track to wild dog hill (whyalla) and stupid me tryed to change the cd in the cd player, and the car drifted to the side of the road, then when i looked up it was too late, went straight over a big lump, stopped, had a look, and instead of my wheel being l is it / (drivers side front wheel)
    ive got some pics, i dont knw what parts i need can someone tell me what ive broke or bent and tell me what i need, and btw the car is very low at the front, thats why i took a pic of the otherside with the mag to show how low it is.
    im freaking out here, i love this car to death
    Attached Thumbnails Attached Thumbnails What Have i Done HELP HELP HELP HELP-my-accident-001.jpg   What Have i Done HELP HELP HELP HELP-my-accident-002.jpg   What Have i Done HELP HELP HELP HELP-my-accident-004.jpg   What Have i Done HELP HELP HELP HELP-my-accident-005.jpg   What Have i Done HELP HELP HELP HELP-my-accident-006.jpg   What Have i Done HELP HELP HELP HELP-my-accident-008.jpg
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    bent the strut where it comes out the cast section down the bottom ide say buy the looks thats why the tyre is hitting the spring mount new strut time
    Dec 2008
    how much do you think that will cost?
    new?
    second hand?
    thanks for your reply mate
    i also noticed the bolt (ball joint thing) is bent too where is connects to the knuckle
    Vp series 2
    Jun 2008
    Your strut is cactus as allready said.
    If you mean the lower arm with the ball joint then compair it to the other side.
    if you mean the on BEHIND the wheel on the steering rack then you will need a new rod for the rack end.
    Also check the strut top plate to see if the strut punched through.
    2nd hand struts are cheap as.
    Check the local dump.
    Dec 2008
    heres the pics, one of the damaged side (drivers side) and the other side which is fine to compare it too (passenger)
    Attached Thumbnails Attached Thumbnails What Have i Done HELP HELP HELP HELP-my-accident-009.jpg   What Have i Done HELP HELP HELP HELP-my-accident-010.jpg
    Dec 2008
    pulled it all apart, the bolt and or ball joint that comes up from the control arm and joins to the knuckle is bent
    в∞ѕтεכ √&
    Jul 2008
    NZ
    what bolt the ball joint one down the bottom of this pick
    Attached Thumbnails Attached Thumbnails What Have i Done HELP HELP HELP HELP-damage.jpg
    Dec 2008
    yeah that bolt is bent
    is it strut usable or do i need a new one?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if the ball joint is bent you need a new one and a new strut
    car
    Jul 2006
    greensy, melb
    you need a new strut, just go to the wreckers and pull one out of another vn, its really not that hard and get a new ball joint
    "A life lived in fear is a life half lived"
    Vp series 2
    Jun 2008
    The strut is ****ed mate.
    You can see in the pics that the tube has broken away from the cast section on the bottom.
    I would still clean the bearing plate on top and look for cracking around the rubber that is bigger then the other side. if in dought when you change the strut then you can change it to.
    When you pull the strut apart you can check the insert and spring for damage. If you are lucky then they will both be ok.
    Dec 2008
    thanks for your replys guys, new struts it is, i hope the spring etc is ok.
    thanks
    rob drag racer's Avatar
    rob drag racer is offline vn vp drag nut
    vp 3.8 with gas new project vn s1 guted strip only
    Jun 2008
    golden beach
    springs should be fine but god dam that's some serious strut damage lucky you and your front wheel Assembly didn't part ways after the fact
    i wont tolerate cretins aiming to cause problems here at jc and nor will i hesitate to let the moderators know
    http://robsbackyarddragraceing.bigblog.com.au/index.do
    vn calais, vs clubsport #137
    Jun 2005
    im from whyalla mate, youl have trouble getting the wreckers to let ya take a strut theyre dicks here.
    did a fair old number on that strut and balljoint, your springs will be fine, hopefully your rack end is aswell check that out.
    lesson learnt for taking a low car on a dirt road :P
  15. #15
    Dec 2008
    lesson learnt very very well mate
  16. #16
    Smallies's Avatar
    Smallies is offline I hate carnies.
    VN Calais / 180SX
    Dec 2008
    Whyalla, SA.
    lol, Im from whyalla too - and it seems to me that the bumps and shit you see on dirt roads out bush are'nt too different to the proper roads in town. My point being - most roads in this city are shocking. Off topic i know - sorry. Good luck with the repairs mate. let us know how it goes.
  17. #17
    vn/vp Speedway Street Sedan
    Sep 2005
    Also it may pay to check out the radius rod that goes from the front of your k-frame to your lower control arm.it may get a bend in it too, as well as it may pull the front of the K-frame in on itself a bit.(where the nut goes on the radius rod at the front through the rubber bush)
  18. #18
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    well we know what the moral of that story is
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
