Results 1 to 13 of 13
Thread: VS BT1 80L tank into VN s1
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Default VS BT1 80L tank into VN s1
    I have bought an 80L tank, sender, straps, fuel pump, the whole lot. It's going into my VN s1 V6.
    The original 63L tank has 2 plugs on the sender unit external to the tank, a round 2pin plug and a straight 2pin plug.
    The new 80L tank has only the one plug, a 4 pin straight plug.
    Anyone able to tell me what goes where?
    Sam
    WTB: mulberry VN interior parts
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by savage1987 View Post
    The original 63L tank has 2 plugs on the sender unit external to the tank, a round plug and a 3 pin straight plug.
    Anyone able to tell me what my options are or at least shed some light on the situation?
    Sam
    I have the books at home - I can look up the wiring diag later - I have both V8 & V6 so should be able to find where the extra wire goes
    and 3 Dangerous non ABS VN's
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    89 VN
    Feb 2009
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    heh your link doesn't work. I assume you mean http://forums.justcommodores.com.au/...-vn-s1-v6.html in which case yes, it is. Read the last page, you'll see why
    edit: also at least half because I just want a bigger tank for practical reasons. My old pickup was bent ... == 55L tank. 100km round trip to work each day.. I just want to carry more fuel
    VP Commodore
    Feb 2008
    Leda, WA
    hey i want to get an 80 ltr tank for my vn as well.. how much are they and are they hard to fit? did you find out about the wireing?
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Wiring, not yet... need to source a plug to suit the 4 pin socket on the new tank before anything else.
    I will let you know on fitment when I get to that
    I'm paying 200 for this one, including pump, sender, straps, etc etc
    89 VN
    Feb 2009
    Fair enough
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    OK to tidy up this thread for anyone who might care, I ended up soldering the VS fuel pump plug onto the body loom side. This matched up nicely with the VS fuel pump's own plug Can't remember if I did the sender plug as well or if it was all the same plug.... either way it's not hard. The wires were even the same colour.
    Tank fit beautifully, is silver with black straps and definitely tidies up the rear of the car a lot. With the tank, a dual rear sway setup and the whole rear axle all painted up it's starting to look a bit tidy under there
    Commodore 1988 VN Calais S1 V6
    Apr 2010
    Adelaide. South Australia.
    I fitted an 80ltr tank straight in to my 1988 VN Calais without any problems at all.
    I purchased the tank from the wreckers and I made sure that I got the wright gear
    with it, eg: tank straps and I got the external fuel pump as well as the internal
    fuel pump and make sure of the fuel pump connections.
    All of this was from the same vechile, a VQ Statesman except for the tank straps
    that came from a VN sedan.
    My suggestion to you would have been to make sure
    what you needed before purchasing and make sure that
    you get the wright tank straps, the Statesman straps are
    the wrong ones.
    You need the straps from an 80ltr sedan tank as I found
    out.
    My 80ltr tank is fitted with out any problems and is going
    well, it just costs a bit more to fill the tank now, you just
    feel it in the hip pocket.
    If I was you I would go back to where you purchased your
    tank and see if you can exchange the fuel pump for a
    VN 80ltr fuel pump as this would solve all of your problems.
    I hope that this information will help you, good luck with
    your endevours.
    Cheers.
    Bob...
    bobmat111.
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    lol, I don't have any problems with my install man
    And bonus, I only run a single pump. No ****ing around with 2 pumps - double the hassle.
    In fact I just changed it for a Walbro so no fuelling issues for me
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    I want to get rid off that external pump on my V8, did any of the 80L tanks come with a single pump?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Apr 2010
    Yes I have seen some 80ltr tanks with a single fuel pump.
    The 80ltr tanks with the 2 fuel pumps were that the internal
    pump was a low pressure and the external pump was a high
    pressure pump.
    I am running the twin pumps as that was the way it was
    when I purchased the 80 ltr tank.
    I do also have spare fuel pumps, internal and external just
    incase of any problems.
    Cheers.
    Bob...
    bobmat111.
  1. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  2. VS - how many k's to the tank
    By iroczinoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-02-2009, 12:16 PM
  3. W.A 80l Gas tank f.s
    By gone_nutz13 in forum Parts And Other Items For Sale
    Last Post: 15-09-2008, 09:37 PM
  4. I got GAS!! How many Ks out of a tank? ?
    By deserthead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-08-2006, 06:03 PM
  5. How Many K's To A Tank
    By Benji in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 10:43 PM
