Hey, i have been having a little problem with my VP. One second its running great, then when i start it up again after ive driven it the idle/revs rise then drops n rise and drop erratically then when i put it in drive it stalls.Then i start it again and can drive away. Under load its fine. Changed injector seal, injectors are also good. The Throttle position sensor is new. Checked the coil packs and there good. Ive checked the car for codes and nothing comes up.
Anyone have any ideas? Thanks.
Check the MAP sensor, if that checks out, perhaps try cleaning out your IAC valve?
Check out my VP right 'ere!
try cleaning the tb and iac valve on the tb might help
Originally Posted by Smidy
I have also cleaned the tb and checked the iac valve forgot to mention that, ill give the map sensor a try next. Thanks guys.
when you cleaned the throttle body did you by any chance let any carby cleaner dribble down the shaft into the TPS they dont like that.
Nah, i cleaned the TB first then put on a new TPS. Could the fuel system cause such a problem?
I'm guessing the fuel pressure regulator could need looking at, for such a simple unit they're not cheap at all though. I paid cost for mine and it was still just over 80 bucks.
Might be way off target but my VN was doing a similar thing.
The rubber fuel lines inside the tank had perished, which didnt allow fuel to return to the little bowl inside the tank the fuel pump sits in.
changed the tank over been running fine since.
Yeh its really really annoying. Thanks DrJeckyl ill keep that in mind.
i just installed a reco ECU
started it up and straight away sounded smoother.
took for a little drive still good
mine normaly does it in the morning so we'll see how tomoro morning goes
Ah ok. Well im on my second ECU at the moment, got it from the wreckers mite even be faulty.
You where right holden-4-life it was the ECU, it was faulty, i took it back and they gave me another one problem gone.
really?!?
thats awesome dude!
find urs idles so much better?
mines going awesome ay
will be the coolant temp system in the ecu they go all the time
Yeh thats right. Very nice smooth idle, runs nice now.
