is there any other differences to the vn and vp inlet manifolds other than the thermostat
wat i m trying to get at is can i put my vn inlet manifolds on a vp v6 as my vn manifolds have my gas vapor injectos drilled into them?
cheers
stevo
Series 1 vn is different to series 2 vn from memory (ie pretty sure you wont be able to use your smani if its a series 1 i think, without major work.)
could be wrong![]()
you could but you need to weld the PCV valve hole in the drivers side head i think.and you will need to fit the VN coolant tank etc.
